Environment:
- ArcGIS Server Enterprise Standard 10.4.1
- SQL Server Standard 2012
- Collector 10.4.2 Android
- Web map hosted on AGOL
Accessing the map and taking it offline initially works just fine; existing features in the FS appear in the offline map as well. Able to navigate & collect just fine. When I sync, the process runs, error but nothing is pushed up. If I make edits elsewhere (using the FS OR editing directly in desktop), no changes are pulled down either. No errors in the server logs. I tried connected via WiFi as well as (4G LTE) Cellular and still nothing syncs.
No attachments or related tables. Editor tracking enabled and two fields have domains.
I'm at a loss as to where to start diagnosing this problem.
