The specified Number of classes value is the maximum number of clusters that can result from the clustering process. However, the number of clusters in the output signature file may not be the same as the number specified for the number of classes. This situation occurs in the following cases: The values of data and the initial cluster means are not evenly distributed. In certain ranges of cell values, the frequency of occurrences for these clusters may be next to none. Consequently, some of the originally predefined cluster means may not have a chance to absorb enough cell members. Clusters consisting of fewer cells than the specified Minimum class size value will be eliminated at the end of the iterations. Clusters merge with neighboring clusters when the statistical values are similar after the clusters become stable. Some clusters may be so close to each other and have such similar statistics that keeping them apart would be an unnecessary division of the data.
