Hi Robert,Here's a link to a help topic that explains how to override the default strings in the JSAPI. https://developers.arcgis.com/javascript/jshelp/inside_bundle.html
require(["dijit/Tooltip", "dojo/domReady!"], function(Tooltip){ new Tooltip({ connectId: ["HomeButton"], label: "Home", orient: ['before'], });
.HomeButton .tooltip { font-family: Arial !important; font-size: 11px !important; font-weight: bold !important; background-color: white !important; }
The link I posted shows how to change the default text for the tooltip. Are you trying to change the text or do you want to modify the appearance of the tooltip?
<!DOCTYPE HTML> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Home Extent</title> <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { padding:0; margin:0; height:100%; } #HomeButton { position: absolute; top: 95px; left: 20px; z-index: 50; } [data-title]:hover:after { content: attr(data-title); padding: 4px 8px; color: #333; position: absolute; left: 0; top: 100%; white-space: nowrap; z-index: 20px; -moz-border-radius: 5px; -webkit-border-radius: 5px; border-radius: 5px; -moz-box-shadow: 0px 0px 4px #222; -webkit-box-shadow: 0px 0px 4px #222; box-shadow: 0px 0px 4px #222; background-image: -moz-linear-gradient(top, #eeeeee, #cccccc); background-image: -webkit-gradient(linear,left top,left bottom,color-stop(0, #eeeeee),color-stop(1, #cccccc)); background-image: -webkit-linear-gradient(top, #eeeeee, #cccccc); background-image: -moz-linear-gradient(top, #eeeeee, #cccccc); background-image: -ms-linear-gradient(top, #eeeeee, #cccccc); background-image: -o-linear-gradient(top, #eeeeee, #cccccc); } </style> <script src="//js.arcgis.com/3.8/"></script> <script> require([ "esri/map", "esri/dijit/HomeButton", "dojo/i18n!esri/nls/jsapi", "dojo/query", "dojo/dom-attr", "dojo/domReady!" ], function( Map, HomeButton,esriBundle, query, domAttr ) { var map = new Map("map", { center: [-56.049, 38.485], zoom: 3, basemap: "streets" }); var home = new HomeButton({ map: map }, "HomeButton"); home.startup(); query(".home").forEach(function(node){ //remove the title attribute //Get the title attribute if(domAttr.get(node, "title") === esriBundle.widgets.homeButton.home.title){ //replace the title attribute with data-title domAttr.remove(node, "title"); domAttr.set(node, "data-title", esriBundle.widgets.homeButton.home.title ) } }); }); </script> </head> <body> <div id="map" class="map"> <div id="HomeButton"></div> </div> </body> </html>
Ok so the current tooltip for the Home Button is generated using the HTML title attribute Basically when you add the title attribute to an HTML tag the browser will display a tooltip. The style is browser dependent and I don't know of a way to modify the style. One approach might be to remove the title attribute then add a new one - maybe data-title and then use the mechanism you are using to generate the other tooltips to generate that one. Here's a sample that show hiding the existing tooltip and creating a new one using css.
If you're using an IDE that has debugging, you can pause it and examine esriBundle. That's how I was able to find the right property in this thread.
<div class="LocateButton" role="presentation" id="LocateButton" widgetid="LocateButton" style="display: block;"> <div class="locateContainer"> <div data-dojo-attach-point="_locateNode" role="button" class="zoomLocateButton" title="Find my location"><span>My Location</span></div> </div> </div>
geoLocate = new LocateButton({ map: map, }, "LocateButton"); geoLocate.startup(); query(".zoomLocateButton").forEach(function(node){ //remove the title attribute //Get the title attribute if(domAttr.get(node, "title") === esriBundle.widgets.locateButton.locate.title){ //replace the title attribute with data-title domAttr.remove(node, "title"); domAttr.set(node, "title", esriBundle.widgets.locateButton.locate.title ) } });
[title]:hover:after { content: attr(title); text-align: center; font-family: Arial; font-size: 12px; font-weight: bold; background-color: white; border: 1px solid #000000; border-radius: 1px; padding: 4px 8px; left: 40px; width: 125px; z-index: 20px; position: absolute; }
var homeText = esriBundle.widgets.homeButton.home.title; var locateText = esriBundle.widgets.locateButton.locate.title; geoLocate.on("load", function(){ query('div[title ="' + locateText + '"]').forEach(function(node){ domAttr.remove(node, "title"); domAttr.set(node, "data-title", locateText); }); }); home.on("load", function(){ //Remove default tooltip for home button query('div[title ="' + homeText + '"]').forEach(function(node){ domAttr.remove(node, "title"); domAttr.set(node, "data-title", homeText); }); });
It looks like the issue is that the title attribute isn't getting removed from the locate button - perhaps due to a timing issue. It seems to work if I wait and remove the text after the locate button has loaded. Here's some sample code that shows this: var homeText = esriBundle.widgets.homeButton.home.title; var locateText = esriBundle.widgets.locateButton.locate.title; geoLocate.on("load", function(){ query('div[title ="' + locateText + '"]').forEach(function(node){ domAttr.remove(node, "title"); domAttr.set(node, "data-title", locateText); }); }); home.on("load", function(){ //Remove default tooltip for home button query('div[title ="' + homeText + '"]').forEach(function(node){ domAttr.remove(node, "title"); domAttr.set(node, "data-title", homeText); }); });
var map; var bMap = "topo"; function changeBasemap(bm) { bMap=bm; map.setBasemap(bMap); } require(["esri/map", "esri/toolbars/navigation", "dojo/on", "dojo/parser", "dijit/registry", "dijit/Toolbar", "dijit/form/Button", "esri/dijit/OverviewMap", "esri/dijit/Scalebar", "esri/dijit/LocateButton", "esri/dijit/HomeButton", "dojo/i18n!esri/nls/jsapi", "dojo/query", "dojo/dom-attr", "dojo/domReady!"], function(Map, Navigation, on, parser, registry, Toolbar, Button, OverviewMap, Scalebar, LocateButton, HomeButton, esriBundle, query, domAttr ){ esriBundle.widgets.homeButton.home.title = "HOME" esriBundle.widgets.locateButton.locate.title = "FIND MY LOCATION" parser.parse(); var navToolbar; map = new Map("map", { basemap: "topo", center: [-107.646372, 43.433484], zoom: 7, slider: "small" }); on(map, "load", addDataLayersInit); on(map, "layers-add-result", initTOC); //on(map, "layers-add-result", initTOC_Obs); var scalebar = new Scalebar({ map: map, // "dual" displays both miles and kilmometers // "english" is the default, which displays miles // use "metric" for kilometers scalebarUnit: "dual", attachTo:"bottom-right" }); geoLocate = new LocateButton({ map: map, }, "LocateButton"); geoLocate.startup(); query(".zoomLocateButton").forEach(function(node){ //remove the title attribute //Get the title attribute if(domAttr.get(node, "title") === esriBundle.widgets.locateButton.locate.title){ //replace the title attribute with data-title domAttr.remove(node, "title"); domAttr.set(node, "title", esriBundle.widgets.locateButton.locate.title ) } }); var home = new HomeButton({ map: map }, "HomeButton"); home.startup(); query(".home").forEach(function(node){ //remove the title attribute //Get the title attribute if(domAttr.get(node, "title") === esriBundle.widgets.homeButton.home.title){ //replace the title attribute with data-title domAttr.remove(node, "title"); domAttr.set(node, "data-title", esriBundle.widgets.homeButton.home.title ) } }); navToolbar = new Navigation(map); on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler); registry.byId("zoomprev").on("click", function(){ navToolbar.zoomToPrevExtent(); }); registry.byId("zoomnext").on("click", function(){ navToolbar.zoomToNextExtent(); }); function extentHistoryChangeHandler(){ registry.byId("zoomprev").disabled = navToolbar.isFirstExtent(); registry.byId("zoomnext").disabled = navToolbar.isLastExtent(); } var overviewMapDijit = new OverviewMap({ map: map, visible: false, attachTo: "bottom-right", width: 200, height: 200 }); overviewMapDijit.startup(); });
Robert,You'll want to replace your existing code that creates the home and locate button with the code I provided.
Are you sure you're looking at the right variable? I'm seeing these options for the overview map widget[ATTACH=CONFIG]32878[/ATTACH]
Are you sure you're looking at the right variable? I'm seeing these options for the overviewmap widget[ATTACH=CONFIG]32878[/ATTACH]
esriBundle.widgets.overviewMap.NLS_show.title = "SHOW" var locateText = esriBundle.widgets.overviewMap.NLS_show.title; var overviewshowText = esriBundle.widgets.overviewMap.NLS_show.title; overviewMap.on("load", function(){ query('div[title ="' + overviewshowText + '"]').forEach(function(node){ domAttr.remove(node, "title"); domAttr.set(node, "show-title", overviewshowText); }); });
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Overview Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/dijit/OverviewMap", "dojo/parser", "dojo/i18n!esri/nls/jsapi", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( Map, OverviewMap, parser, esriBundle ) { parser.parse(); map = new Map("map", { basemap: "topo", center: [-122.445, 37.752], zoom: 14 }); esriBundle.widgets.overviewMap.NLS_show = "Testing"; var overviewMapDijit = new OverviewMap({ map: map, visible: true }); overviewMapDijit.startup(); }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width: 100%; height: 100%; margin:0;"> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0"> </div> </div> </body> </html>
This should work
Did you try what Kelly suggested in an earlier post?
var showText = esriBundle.widgets.overviewMap.NLS_show; overviewMapDijit.on("load", function(){ query('div[title ="' + showText + '"]').forEach(function(node){ domAttr.remove(node, "title"); domAttr.set(node, "data-title", showText); }); });
[data-title]:hover:after { content: attr(data-title); text-align: center; font-family: Arial; font-size: 11px; font-weight: bold; background-color: white; border: 1px solid #000000; border-radius: 1px; padding: 4px 8px; left: 40px; width: 40px; z-index: 20px; position: absolute; }
Can you show an example in Fiddle or JSBin?
