I would like to access Esri's ArcGIS Online map services for an application I am working on. This application is accessed via https, so the services also need to be https. Is there a way to connect to these ArcGIS Online services through https?
You can call the services from https://server.arcgisonline.com/arcgis/rest/
If you are trying to use secured map services check this
HTTPS Connection to ArcGIS Online Map Services Now Available | ArcGIS Blog
ArcGIS Server web services—ArcGIS Online Help | ArcGIS
Configuring HTTPS on ArcGIS Server when accessed through ArcGIS Web Adaptor—Documentation (10.4) | ArcGIS for Server
