from reportlab.pdfgen import canvas from reportlab.lib.pagesizes import letter from reportlab.lib.units import inch import os, glob, sys, time import textwrap #Logic for averyLabel 5160 def avery5160(outfile, font, font_size, addressInput): print 'Creating labels in Avery 5160 format' # PDF vars if os.path.exists(outfile): os.remove(outfile) out_pdf = canvas.Canvas(outfile, pagesize = letter) out_pdf.setFont(font, font_size) addressItem = addressInput.split('$') hs = 0.25 vs = 10.3 horizontal_start = hs * inch #staring point of label horizontally vertical_start = vs * inch #starting point of label vertically count = 0 #initially the count is 0 for item in addressItem: if count > 0 and count % 30 == 0: out_pdf.showPage() out_pdf.setFont(font, font_size) horizontal_start = hs * inch vertical_start = vs * inch elif count > 0 and count % 10 == 0: horizontal_start = horizontal_start + 2.8 *inch vertical_start = vs * inch label = out_pdf.beginText() label.setTextOrigin(horizontal_start, vertical_start) details = item.split('~') for detail in details: if len(detail) > 45: name = detail[0:44] label.textLine(name) name = detail[44:60] label.textLine(name) else: label.textLine(detail) out_pdf.drawText(label) vertical_start = vertical_start - 1.05 * inch count = count + 1 out_pdf.showPage() out_pdf.save() print '\nCreated %s\n' %outfile
