I am trying to add created records in one layer to another feature layer using ArcPy script. Is there any sample script to do so? Thanks in advance.
Lots of "ifs" there.
I would start with consolidating your data so you don't have to cycle through a number of layers that you know won't meet the conditions in the first place.
You don't indicate :
In some cases directing to "memory" workspace helps Write geoprocessing output to memory
Also, is 5 minutes really too long? 😉 (ie. is this a 911 or similiar application?)
Hi @DanPatterson
I have come up with a solution to the task I wanted to accomplish, but the script is taking around 5 minutes to do perform the task(s). I need to minimise the time of processing, great to have your expert suggestion if I can reduce the processing time,
for m in aprx.listMaps(): for layer in aprx.activeMap.listLayers(): if(layer.name[0:12]=="CGD.PARCELS_" and layer.getSelectionSet()): arcpy.management.Append(layer, "BASEDATA", "NO_TEST") arcpy.SelectLayerByLocation_management("BASEDATA","ARE_IDENTICAL_TO",layer)
Related... with unresolved questions in the post
Copying exact record in another feature class while creating the record in a feature class using ArcPy....
