You're referring to the VBA editor, not Visual Studio. ESRI no longer supports VBA but I believe you can still contact them and get a license for it if you want to use it for ArcGIS 10. Starting with the 10.1 release, VBA will no longer be available.
Actually, I can get it to open a form, but the form is not "owned" by the application window, so it floats independently and can get hidden behind the application window or other windows if I'm not careful. I have found a grand total of ZERO help or discussion of this topic so far.
Public Class ModelessDialog Implements System.Windows.Forms.IWin32Window Private hwnd As System.IntPtr ''' <summary> ''' Returns the form handle. ''' </summary> ''' <value></value> ''' <returns></returns> ''' <remarks></remarks> Public ReadOnly Property Handle() As System.IntPtr Implements System.Windows.Forms.IWin32Window.Handle Get Return hwnd End Get End Property ''' <summary> ''' Constructor. ''' </summary> ''' <param name="handle">The form handle passed as an IntPtr</param> ''' <remarks></remarks> Public Sub New(ByVal handle As System.IntPtr) hwnd = handle End Sub ''' <summary> ''' Constructor. ''' </summary> ''' <param name="handle">The form handle passed as an integer</param> ''' <remarks></remarks> Public Sub New(ByVal handle As Integer) hwnd = CType(handle, IntPtr) End Sub End Class
Neil, VBA is available in 10.1. I have the licenses installed and have run it.
