With UpdateLayer, are you using False for the symbology_only parameter? It defaults to True, so the label properties will only come across if you specify it as False.For example: arcpy.mapping.UpdateLayer(df, updateLayer, sourceLayer, False)Keep in mind this will bring all layers properties including symbology, font, font size, label expression, etc., so everything will need to be defined in the update .lyr file. David
Setting False for me seems to overwrite EVERYTHING; the attributes, layer name, all of it.
It seems to have simple ran a Remove Layer and then an Add Layer rather than commuting the layer properties.
I simply want my layer to be 50% transparent and have the labels displayed with 15 point Y offset and Halo around the text.
Anyone experience this?
