just made it! everything works fine! thanks a lot!- Made recursive method for this!
Note : if you have more than one possible level of group layers, you'll have to enhance the code to go down the legend tree hierarchy
private void Legend_Refreshed(object sender, Legend.RefreshedEventArgs e) { if (e.LayerItem.LayerItems == null) return; foreach (var layerItem in e.LayerItem.LayerItems) { if (layerItem.IsGroupLayer) layerItem.ImageSource = new BitmapImage(new Uri("/Neolant.TORIS.WebClient;component/Images/group.png", UriKind.Relative)); else layerItem.ImageSource = new BitmapImage(new Uri("/Neolant.TORIS.WebClient;component/Images/layer.png", UriKind.Relative)); } // Note you could also set the ImageSource of e.LayerItem itself (e.g. depending on the type of map service), and you would have to change the MapLayerTemplate as well }
<esri:Legend x:Name="mapLegend" Background="White" Width="Auto" LayerItemsMode="Tree" ShowOnlyVisibleLayers="False" Refreshed="Legend_Refreshed" HorizontalAlignment="Left"> <esri:Legend.MapLayerTemplate> <DataTemplate> <StackPanel Orientation="Horizontal" > <Image Source="/Neolant.TORIS.WebClient;component/Images/mapservice.png" Margin="0,0,2,0" VerticalAlignment="Center" Width="20" Height="20"/> <TextBlock Text="{Binding Label}" VerticalAlignment="Center" HorizontalAlignment="Center"/> </StackPanel> </DataTemplate> </esri:Legend.MapLayerTemplate> <esri:Legend.LayerTemplate> <DataTemplate> <StackPanel Orientation="Horizontal" > <StackPanel.Resources> <Image x:Name="imgLayerItem" Source="/Neolant.TORIS.WebClient;component/Images/layer.png" Margin="0,0,2,0" VerticalAlignment="Center" Width="20" Height="20" /> <TextBlock Text="{Binding Label}" VerticalAlignment="Center" HorizontalAlignment="Center" Margin="0,0,0,0"/> </StackPanel> </DataTemplate> </esri:Legend.LayerTemplate> </esri:Legend>
