I found a number of ways to do this but there is an issure with the model not being georeferenced. Is there any way to georeference the model within ArcGIS?
Hi,I was just wondering if there is a way of doing this from sketchup 8 to ArcGis 9.3?Any help would be greatly appreciated.Jason
Hi Imran,The ArcGIS SketchUp plugin is no longer supported at 10.Here are the two main feature CREATION workflows, using 10:(1) Starting with a SKP (or DAE/3DS/FLT) file- Start editing in Scene or Globe (against a multipatch feature class)- If required, create an Edit Template for the multipatch layer- Select the multipatch template in the Create Features window- This enables the Insert tool (for placing multipatch features)- Click in the view where you want the 3D model to be placed- When prompted, navigate to the source SKP file- A new multipatch feature is created in the geodatabase (imported from the source 3D file), located at the point where you clicked - Move / rotate / scale the new multipatch feature, as needed- Optionally populate feature attributes, save edits
When doing this, the textures of my model only become partly visible, or not at all. Why does this happen?
DAEs exported from SU lack georeference. ...
Does anybody know what this is, and how to fix it?
It could have something to do with the invalid intersections. You mention some plugins which can assist me, can you name some of them?
Hi Imran,The ArcGIS SketchUp plugin is no longer supported at 10.Here are the two main feature CREATION workflows, using 10:(1) Starting with a SKP (or DAE/3DS/FLT) file- Start editing in Scene or Globe (against a multipatch feature class)- If required, create an Edit Template for the multipatch layer- Select the multipatch template in the Create Features window- This enables the Insert tool (for placing multipatch features)- Click in the view where you want the 3D model to be placed- When prompted, navigate to the source SKP file- A new multipatch feature is created in the geodatabase (imported from the source 3D file), located at the point where you clicked - Move / rotate / scale the new multipatch feature, as needed- Optionally populate feature attributes, save edits(2) Starting with a GIS feature (such as a building footprint)- Use a feature attribute (such as bld height) to extrude the footprint into a block representation- Use the 'Layer 3D to Feature Class' GP tool to create a multipatch feature class- Select the multipatch feature/s you want to update, then use the 'Multipatch to COLLADA' GP tool to export them to DAE files - Load and edit the COLLADA files in SketchUp (or some other application)- Start Editing in Scene or Globe (against the applicable multipatch data)- Select the feature whose geometry you want to update from the DAE- Use the 3D Editor > Replace with Model command to switch out the existing block geometry with the more complex geometry (and optional textures) you created in the edited 3D model (COLLADA file).- Save editsHope it helps!Gert3D Team
