The clipped raster has the same cell numbers as the original one!!! Why?Please, see the attached image that shows the case (particularly the tables!!!)The clipped raster has the same cell numbers as the original one (exactly the same) despite the fact that the clipped one is just a part of the original raster!!! Of course�?�really weird!!!!!What might be the problem?Thank youRegardsJamal
you have to set the extents explicitly in your Environments to be the extent of the layer used to clip the input raster
Hi Jamal,When you run the Clip tool, it does not automatically update your Attribute Table. There is an enhancement request to have the Attribute Table updated. If you run the Build Raster Attribute Table tool, you will get the updated information.Patrick
Dear all,I have the same problem as Jamal had when I try to clip my raster.I'm working with WorldClim data and I want to clip my variables at Iberian Peninsula scale.But the clipped raster has alwyas the same cell numbers as the original one!!! I'm using ArcGIS10.My raster are in GRID format and I set all the extents explicitly in Environments but it still doesn't work.Any idea ahat might be the problem this time?And more important, how I can I solve it?Thanks in advance,Best regards,Rita
