<?xml version="1.0" encoding="utf-8"?> <mx:UIComponent xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" width="100%" height="100%" > <esri:WMSLayer id="wmslayer1" /> <esri:GraphicsLayer id="layer2" /> <esri:GraphicsLayer id="layer3" /> <esri:GraphicsLayer id="layer4" /> <esri:GraphicsLayer id="layer5" /> </mx:UIComponent>
The UIComponent class is the base class for all visual components, both interactive and noninteractive.The UIComponent class is not used as an MXML tag, but is used as a base class for other classes.
private var myGraphicsLayersCollection:ArrayCollection = new ArrayCollection(); private function addGraphicsLayerToCollection():void { var grLayer:GraphicsLayer = new GraphicsLayer(); grLayer.id = "grLayer1"; grLayer.name = "First Gr Layer"; myGraphicsLayersCollection.addItem(grLayer); } private function getGraphicsLayerFromCollectionById(layerId:String):GraphicsLayer { for each (var layer:GraphicsLayer in myGraphicsLayersCollection) { if (layerId == layer.id) { return layer; } } return null; } private function removeGraphicsLayerFromCollectionById(layerId:String):Boolean { var isRemoved:Boolean = false; for each (var layer:GraphicsLayer in myGraphicsLayersCollection) { if (layerId == layer.id) { var index:int = layerList.getItemIndex(layer); layerList.removeItemAt(index); isRemoved = true; break; } } return isRemoved; } private function collectionToMap():void { for each (var layer:GraphicsLayer in myGraphicsLayersCollection) { // each layer extends UIComponent, so its ID is unique var existingLayer:Layer = mapMap.getLayer(layer.id); if (!existingLayer) mapMap.addLayer(layer); } }
