Hi there. I have a different issue -- I have a referenced mosaic dataset with a number of functions applied. Since it covers much of South America, I need to clip out a small portion as a flat raster file to send to someone. When I view the mosaic and classify it in Arcmap 10.2, it looks great, just like I need it. Now, I export my area using Data > Export Data > to a .tif file. Usually, this works great for clipping rasters to an AOI. However, when I do it now, it creates my new raster, but WITHOUT THE FUNCTIONS APPLIED. Why is this happening? Is there a better method?Thank you!
...I have been able to clip the images and mosaic them together with no problem. The issue comes when trying to export the dataset to a single image, currently a tiff, so that the other application can use it for clipping.The issue is that the exported image displays as all black but it has RGB values when you use the info tool to click around the image. It also has the issue of not maintain the true extent of the entire state. ... This is done using 10.1.
