import arcpy # Create an Array object for the multi-part feature. array = arcpy.Array() # List of lists of coordinates. partList = [['1.0;1.0','1.0;10.0','10.0;10.0','10.0;1.0'],            ['20.0;20.0','20.0;30.0','30.0;30.0','30.0;20.0'],            ['-20.0;-20.0','-20.0;-30.0','-30.0;-30.0','-30.0;-20.0']] # For each part, create a sub-array and populate it with #  point objects for coordList in partList:    # Create an Array object for each part.    sub_array = arcpy.Array()    # For each coordinate set, create a point object and add the x- and    #  y-coordinates to the point object, then add the point object    #  to the array object.    for coordPair in coordList:        x, y = coordPair.split(";")        pnt = arcpy.Point(x,y)        sub_array.add(pnt)    # Add in the first point of the array again to close the polygon boundary    sub_array.add(sub_array.getObject(0))    # Add the sub-array to the main array    array.add(sub_array) # Create a multi-part polygon geometry object using the array object multiPartPolygon = arcpy.Polygon(array) # Use the geometry object to create a feature class arcpy.CopyFeatures_management(multiPartPolygon, "c:/temp/geomTest.shp")
