<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"      xmlns:s="library://ns.adobe.com/flex/spark"      xmlns:mx="library://ns.adobe.com/flex/mx"      xmlns:esri="http://www.esri.com/2008/ags"      pageTitle="Find features in Map Layers">   <s:layout>  <s:VerticalLayout horizontalAlign="center"/> </s:layout>   <fx:Script>  <![CDATA[   import com.esri.ags.Graphic;   import com.esri.ags.events.FindEvent;   import com.esri.ags.geometry.Geometry;      private function doFind():void   {    findTask.execute(myFindParams);   }      private function executeCompleteHandler(event:FindEvent):void   {    myGraphicsLayer.clear();    var graphic:Graphic;    resultSummary.text = "Found " + event.findResults.length + " results.";    var resultCount:int = event.findResults.length;    for (var i:Number = 0; i < resultCount; i++)    {     graphic = event.findResults.feature;     graphic.toolTip = event.findResults.foundFieldName + ": " + event.findResults.value;          switch (graphic.geometry.type)     {      case Geometry.MAPPOINT:      {       graphic.symbol = smsFind;       break;      }      case Geometry.POLYLINE:      {       graphic.symbol = slsFind;       break;      }      case Geometry.POLYGON:      {       graphic.symbol = sfsFind;       break;      }     }     myGraphicsLayer.add(graphic);    }   }  ]]> </fx:Script>   <fx:Declarations>  <!-- Symbol for Find Result as Polyline -->  <esri:SimpleLineSymbol id="slsFind"          width="3"          alpha="0.9"          color="0xFFFF00"          style="solid"/>    <!-- Symbol for Find Result as Point -->  <esri:SimpleMarkerSymbol id="smsFind"         alpha="0.9"         color="0xFFFF00"         size="11"         style="square">   <esri:SimpleLineSymbol color="0x000000"/>  </esri:SimpleMarkerSymbol>    <!-- Symbol for Find Result as Polygon -->  <esri:SimpleFillSymbol id="sfsFind"          alpha="0.7"          color="0xFFFF00"/>    <!-- Find Task -->  <esri:FindTask id="findTask"        executeComplete="executeCompleteHandler(event)"        url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer"/>  <esri:FindParameters id="myFindParams"        contains="true"        layerIds="[0,1,2]"        outSpatialReference="{map.spatialReference}"        returnGeometry="true"        searchFields="[FID]"        searchText="{fText.text}"/> </fx:Declarations>   <s:BorderContainer width="100%" height="40"        backgroundColor="0xDDDDFF">  <s:layout>   <s:HorizontalLayout horizontalAlign="center" verticalAlign="middle"/>  </s:layout>  <s:Label text="Search for FID:"/>  <s:TextInput id="fText"      enter="doFind()"      maxWidth="400"      text="0"/>  <s:Button click="doFind()" label="Find"/> </s:BorderContainer>   <s:Label id="resultSummary" height="15"/>   <mx:VDividedBox width="100%" height="100%">  <esri:Map id="map">   <esri:extent>    <esri:Extent xmin="-126" ymin="24" xmax="-67" ymax="50">     <esri:SpatialReference wkid="4326"/>    </esri:Extent>   </esri:extent>   <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer"/>   <esri:GraphicsLayer id="myGraphicsLayer"/>  </esri:Map>  <mx:DataGrid width="100%" height="40%"      dataProvider="{findTask.executeLastResult}">   <mx:columns>    <mx:DataGridColumn width="70"           dataField="layerId"           headerText="Layer ID"/>    <mx:DataGridColumn dataField="layerName" headerText="Layer Name"/>    <mx:DataGridColumn dataField="foundFieldName" headerText="Found Field Name"/>    <mx:DataGridColumn dataField="value" headerText="Found Field Value"/>   </mx:columns>  </mx:DataGrid> </mx:VDividedBox>  </s:Application>
