In 2017 this is still a problem. It's a disgrace that an application in this day and age cannot recover gracefully from a brief database/network outage.
It's completely insane that the software doesn't even provide an accurate, user-friendly, human-readable error message for this situation.
Shame, ESRI, shame!
Please understand that you are saying the equivalent of, "It's a disgrace that a painter can't immediately continue his brush stroke when the ladder he was using is dragged down the street in a brief safety line mishap. It's completely insane that the brush box doesn't articulate this hazard."
For a TCP/IP application, losing network access, even briefly, severs the communication link. Even if the database client software has the ability to re-establish communication, it's unlikely that this reconnection protocol will be entirely seamless with respect to the client application, and the hash that this makes within the transaction model isn't likely to make application recovery any easier.
It takes a great deal of effort to find the right balance of database API options to implement geodatabases with reliable network access. It's unlikely that the same order of magnitude of performance would be achievable if the client library were optimized for unreliable connectivity (assuming this is even possible). It doesn't seem fair to blame a third party for the error messages generated in some other vendor's library by failure five or six levels away in the OSI model.
If you need to work with unreliable network access, you need to use tools which do not require continuous connectivity. There are a number of available options using the Esri technology stack, including disconnected editing and feature stream editing with REST endpoints.
- V
Here is my much less technical take on this. Databases can become corrupt; the different files that make them up
can get out of synch, or a record can be incompletely saved or saved on a disk sector with problems. I have had
this happen many years ago on a small PC network, and the database continued to work until the bad data area was
accessed. Then we had to reenter everything entered since the failure after restoring to an earlier, safer date (a
date that was not easy to figure out) because a good chunk of the data could not be viewed or printed.
I would prefer database software drop everything in process when there is a lost connection and avoid even the
slightest chance of corruption, especially if it does not quickly provide reliable information about the integrity
of the database after reconnection. I assume it lost my edits but that I can renter them. This has always happened
with SDE, and I have more confidence in it than my file-based databases such as FGDBs.
I will have to respectfully disagree. Even on a reliable network, there are many reasons why a database can be momentarily disconnected. Other applications cope with this sort of thing fine. I appreciate that it's not simple, but it's a shame that ESRI are not even trying.
Database transactions make it feasible.
Using database transactions on a proper RDBMS avoids that kind of corruption. A transaction makes each logical group of database operations either all-or-nothing. If the database doesn't get the 'commit' at the end of the transaction, it can roll back all of the parts of the transaction. It is always internally consistent.
Corruption can of course occur for many other reasons.
I've done more than my fair share of programming in the TCP/IP stack, and there really isn't any reason for transient disconnections on a reliable network. Since TCP/IP hides the physical layer from the application, frequent TCP connection failures are the very definition of an unreliable network.
The very nature of Direct Connect connections is to utilize the network protocol of the database API. If they report a connection failure, it's not possible to reject the error and force it to remain connected. At this point, all the cached commands in the Direct Connect thread queue are invalidated. It's not just that this is a non-simple task, it's a nigh-on impossible task. If you then multiply by a dozen different Direct Connect drivers, the magnitude of the problem is exposed.
In fact, database transactions are what make it impossible. You can't rejoin a transaction after it fails, and that low-level failure during a COMMIT is what invalidates the uncommitted changes. Remember that the versioned geodatabase model saves the individual undo-able edits as states in the versioned state tree, and the act of "saving" is really only changing the state of the version associated with the edit session to the last created state. So, in a sense, you can access the committed states through the point where the editing failed, but you'd need to take heroic (and unsupported) measures to align the version to that state. If the edit session is not versioned, then a simple implicit ROLLBACK erases any memory of the edits.
Best practice remains to save frequently during an edit session.
