At beta 1, the requirement is that the dataset needs to be registered as versioned and default version can be published for editing. At beta 2, editing will be supported for both versioned and non-versioned data.ThanksRavi
So, there will be no support for versions other than default (Would be nice to drive version creation in rest/api, thus edit other versions).
For beta 2, it seems like this is a bit limiting, in that we either use version editing or non version editing, but not both, right?
Feature service can be used to edit default or other versions of the dataset. The choice of version should be made when authoring the map that will be published for editing.Can you please explain further on what you mean here? My understanding is that you can register a dataset as versioned or not register a dataset as versioned and feature service can be used for editing dataset in both cases.
If I have a GDB that is versioned, I would also, like to store date that can be edited via non versioned in the same database that may be setup via a relationship class with the versioned layer(s), maybe I am missing something, but I have always had issues when blending these two ways for editing data in the same database.
What if have a web service which supports creating a new version? Let's say that I want users in the field to submit potential changes which have to be reviewed/moderated. In this case, each user would have their own SDE version.
Hi, Feature services were designed to support one version per service. This workflow allows the author of the service to control which version is exposed through the feature service. If you want to publish multiple versions of the same data, a separate feature service will have to be created for each version. The ability to create new versions through the feature service is not currently supported. The advantage to this workflow is that it prevents end users from selecting the wrong version and it also prevents the end users from creating hundreds of versions that can be very difficult to manage. If you are using versioned data in your feature service you can use QA QC and then reconcile and post the selected edits from the version publish in the feature service to control which edits are maintained in the Geodatabase.Hope this helps, Jessie
