I used a simple app to test the lengths and Areas returned by Geometry Service. I found the geometryService.lengths(geometry) can return accurate lengths of polylines, but it looks like the lengths and areas returned by geometryService.areasAndLengths are exaggerated. e.g. The perimeter of the state of Colorado is around 1300 miles. When I draw a polyline around it, it will return similar number. But if I draw a polygon around it, it will return 1600+ miles and the area is exaggerated accordingly. Does anyone has a clue? I included the complete code in case someone wants to test it.<!DOCTYPE html> <html> <head> <meta charset="utf-8" /> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Draw and Measure</title> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/nihilo/nihilo.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <link rel="stylesheet" type="text/css" href="http://code.jquery.com/ui/1.10.3/themes/start/jquery-ui.css" /> <style> html, body{ font-family: sans-serif; height: 100%; width: 100%; } html, body { margin: 0; padding: 0; } h1,h2,h3 { margin: 0; padding: 0; } header { position: absolute; top: 0; left: 0; right: 0; height: 5em; z-index: 100; } .title_bar { text-align: center; height: 2.4em; background-color: #222; color: #fff; } .title_bar h2 { font-size: 1.3em; padding-top: 5px; letter-spacing: 1px; } .draw_toolbar { height: 2.6em; padding-left: 15px; padding-right: 15px; background-color: #eee; -webkit-box-shadow: 0px 0px 15px -2px black; -moz-box-shadow: 0px 0px 15px -2px black; box-shadow: 0px 0px 15px -2px black; } .draw_tool, .graphic_clear{ display: inline-block; height: 78%; margin-top: .3em; font-size: .9em; font-weight: bold; } #map { position: absolute; top: 5em; bottom: 0; left: 0; right: 0; } .float_right { float: right; } .results { display: none; position: absolute; top: 30px; left: 80px; padding: 10px; width: 200px; height: 60px; background: #fff; z-index: 100; -moz-border-radius: 1px; -webkit-border-radius: 1px; border-radius: 1px; -webkit-box-shadow: 0 0 0 10px rgba(34,34,34,.6); -moz-box-shadow: 0 0 0 10px rgba(34,34,34,.6); box-shadow: 0 0 0 10px rgba(34,34,34,.6); *box-shadow: 0 0 0 10px rgba(154,179,199,.8); } </style> <script src="http://js.arcgis.com/3.6/"></script> <script src='http://code.jquery.com/jquery.min.js'></script> <script src="http://code.jquery.com/ui/1.10.3/jquery-ui.js"></script> <script> var map, toolbar, geometryService, returnedGraphics; require([ "dojo/_base/connect", "dojo/parser", "dijit/registry", "dojo/ready", "esri/config", "esri/map", "esri/toolbars/draw", "esri/graphic", "esri/geometry/Geometry", "esri/geometry/webMercatorUtils", "esri/tasks/GeometryService", "esri/tasks/AreasAndLengthsParameters", "esri/tasks/LengthsParameters", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( connect, parser, registry, ready, esriConfig, Map, Draw, Graphic, Geometry, webMercatorUtils, GeometryService, AreasAndlengthsParameters, LengthsParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol) { ready(function () { //beginning of ready function parser.parse(); esriConfig.defaults.io.proxyUrl = "proxy.php"; esriConfig.defaults.io.alwaysUseProxy = false; map = new Map("map", { basemap: "topo", center: [-105.2404, 39.3396], zoom: 8 }); console.log("Map Created!"); map.on("load", function(){ $(document).ready(jQueryReady); }); }); //end of ready function function jQueryReady(){ map.graphics.clear(); //create toolbar toolbar = new Draw(map); toolbar.on("draw-end", addToMap); //add Geometry Service geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); geometryService.on("areas-and-lengths-complete", outputAreaAndLength); geometryService.on("lengths-complete", outputLength); $('.draw_tool').button().click(function(){ var tool = $(this).text().toUpperCase().replace(/ /g, "_"); toolbar.activate(Draw[tool]); map.hideZoomSlider(); }); $('.graphic_clear').button().click(function(event){ map.graphics.clear(); $('.results').html('').hide(); map.showZoomSlider(); toolbar.deactivate(); }); } function addToMap(event) { var symbol; map.showZoomSlider(); var geom = event.geometry; switch (geom.type) { case "point": symbol = new SimpleMarkerSymbol(); var pointGeographic = webMercatorUtils.xyToLngLat(geom.x, geom.y, true); $('.results').html('Latitude = ' + pointGeographic[0].toFixed(2) + '°' + '</br>' + 'Longitude = ' + pointGeographic[1].toFixed(2) + '°').show(); break; case "polyline": symbol = new SimpleLineSymbol(); //get length var lengthParams = new LengthsParameters(); lengthParams.polylines = [geom]; lengthParams.lengthUnit = GeometryService.UNIT_STATUTE_MILE; lengthParams.geodesic = true; geometryService.lengths(lengthParams); break; default: symbol = new SimpleFillSymbol(); //get length and area var areasAndLengthParams = new AreasAndlengthsParameters(); areasAndLengthParams.lengthUnit = GeometryService.UNIT_STATUTE_MILE; areasAndLengthParams.areaUnit = GeometryService.UNIT_SQUARE_MILES; geometryService.simplify([geom], function(simplifiedGeometries) { areasAndLengthParams.polygons = simplifiedGeometries; geometryService.areasAndLengths(areasAndLengthParams); }); break; } var graphic = new Graphic(geom, symbol); map.graphics.add(graphic); } function outputAreaAndLength(event) { var result = event.result; console.log(JSON.stringify(result)); $('.results').html("Length = " + result.lengths[0].toFixed(2) + " Miles<br/>" + "Area = " + result.areas[0].toFixed(2) + " Sq. Miles").show(); } function outputLength(event) { var result = event.result; console.log(JSON.stringify(result)); $('.results').html("Length = " + result.lengths[0].toFixed(2) + " Miles").show(); } }); //end of require </script> </head> <body> <header> <div class='title_bar'> <h2>Draw and Measure</h2> </div> <div class='draw_toolbar'> <button class='draw_tool'>Point</button> <button class='draw_tool'>Polyline</button> <button class='draw_tool'>Polygon</button> <button class='draw_tool'>Freehand Polyline</button> <button class='draw_tool'>Freehand Polygon</button> <button class='draw_tool'>Rectangle</button> <button class='draw_tool'>Triangle</button> <button class='draw_tool'>Circle</button> <button class='graphic_clear float_right'>Clear</button> </div> </header> <div id='map'> <div class="results"></div> </div> </body> </html>
