There is no attribute transfer with 2 point files anymore?? The attribute transfer tool in Pro has line feature to choose from. In ArcMAP, you could do either. Where is that feature now??
Michelle - just as a heads up, the warning about AGP 2.2 was for the 2.2.2 release. Esri recommends all users uninstall AGP 2.2.2 via the Control Panel via the view installed updates link. AGP 2.2.3 was just released today I believe and fixes the error.
That’s it. That’s the right tool. It is in the spatial adjustment toolbar in ArcMAP. In that tool you can choose any layer in your map. It doesn’t have to be a line feature. The attached is what it is in ArcPro.
Michelle Couden
Cartographer
Certified GIS Analyst
TPP Wellness Contact
Transportation Planning and Programming
Traffic Analysis Section
(512)486-5136
Watch for Cyclists!
Can you provide a screenshot of the Attribute Transfer tool that you have access to at Pro 2.0?
I'm wondering if I'm thinking of a different tool that is packaged in ArcMap in the Spatial Adjustment toolbar.
We have 2.0 because of the warning with 2.2. The Attribute transfer tool is in 2.0 but it only lets you choose a line layer as the source. You could choose any layer in ArcMAP. For Example, point to point. Unless, they added that part of the feature in 2.2?
This is an idea I had on this specific tool:
https://community.esri.com/ideas/15253
Are you saying that this tool has been added to Pro at 2.2.x? If so, it does not have the same capabilities as the similarly named ArcMap tool?
