Hello,The error is pretty straight forward. It is stating that the server doesn't have access to some of those directories, and even lists them. What account are you using for the arcgis server service in windows? This is the account that must have access. You can test this by logging in to the machine as that account, navigating to the path, and just creating a little test folder. If that is successful, let me know and I will give you another test. Thanks-Justin
Have you set also NTFS privileges for user arcgis?
My dear friend, thanks for the reply.The account for ArcGIS Server is arcgis, which is domain user. The existing site server and the new server use the same account. The configure store, the directories, and the logs folder are in arcgisserver folder, which are configured as UNC path, e.g. \\machinename\configure-store, \\machinename\directories, \\machinename\logs. And the arcgis server account is the owner of the arcgisserver folder and its sub-folders.Per your request, I remote destop to the new server, which needs to be added into an existing site for testing, with the user name of arcgis account, which is a domain user in my case. I can create folders and files in the folder of arcgisserver and its sub-folders, config-store, directories, and logs. Anything else that you need me to test?Thanks again.
Thank you for the reply. This means that the NTFS Permissions are correct, and you have network connectivity. The next test I would suggest you do is tor remove the current machine from the site, and then connect this machine to the site. Please note that this will require downtime. This test will see if it is an issue adding the machine, or if it adding a second machine that is the issue. Here are the steps:1. Log into server manager on the currently working machine a. navigate to site/machines b. Click the "X" that is associated with the machine name -- Note: What this will do is remove the machine from the site. This means it will remove the machine from the config store and the directories. All of your configuration will still be there, and we will be able to reconnect it after the test is complete. 2. After the machine is removed, navigate to the second machine a. Instead of join an existing site, select create new site b. When prompted, point to the existing config store and directories --Note: This will not overwrite any existing configurations. You should simply be able to connect to the config store and directories.If this works, then try to connect your other server to this by joining the site. If that doesn't work, then we have discovered there is an issue connecting the second machineIf this doesn't work, then there is an issue connecting this machine to the config store/directories. To clean up simply go to the original machine and select create new site, point to the config store and directories to put things back as they were.Please let me know the results-Justin
