How would I go about making a script that adds multiple fields to an attribute table?
See AddField. I usually have the field name, type, alias, and other properties in a list. For multiple fields, I would then have a list of lists to loop through. In a very rough form, something like:
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'fldName'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TEXT'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'50'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'fldAlias'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> other properties <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'fldName2'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'TEXT'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'50'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'fldAlias2'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> other properties <SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> fld <SPAN class="keyword token">in</SPAN> fields<SPAN class="punctuation token">:</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>dbFeature<SPAN class="punctuation token">,</SPAN>fld<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>fld<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>"<SPAN class="comment token">#","#",</SPAN> fld<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>fld<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>nullable<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>etc<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
