Because the feature does not allow geometry update the feature gets locked into the initial position and cannot be updated.If you do not want to collect a feature at the GPS location you can do a long press on the map and on the white callout tap the arrow and on the options that popup tap Collect Here and that will let you collect the point at that defined location that is not your GPS location but you will not be able to update it after it has been created.Let me know if you have any further questions.Russ
Also you could disable the update capability and just use Create Delete Query which will allow your field crew to create features and move them, delete features and then query them to get the popup info.Russ
