Hello. I have a JS application similar to this sample: https://developers.arcgis.com/javascript/latest/sample-code/visualization-vv-color-animate/live/index.html
I just want to be able to disable the users ability to grab the slider notch and drag it to a new position. I am using JS API Version 4.11.
Add the disabled attribute to the input slider
<input id="slider" type="range" min="1880" max="2017" step="1" value="1984" disabled /><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you yes that worked! It does not let me grab the slider notch at all.
