sdelayer -o register -l ref_mks_constateringen,locatie_wkt -e p -C object01_id -E 120000,350000,180000,420000 -t SDO_GEOMETRY -i esri_sde_irist -u <myuser> -p <mypassword>
ArcSDE 9.3.1 for Oracle10g Build 2784 Tue Oct 27 10:51:14Layer Administration Utility-----------------------------------------------------Layer Description ....: <None>Table Owner ..........: INTWISTable Name ...........: REF_MKS_CONSTATERINGENSpatial Column .......: LOCATIE_WKTLayer Id .............: 911SRID .................: 62Minimum Shape Id .....: 1Offset ...............: falsex: 124236.000000 falsey: 358722.325954System Units .........: 8350.000000Z Offset..............: 0.000000Z Units ..............: 1.000000Measure Offset .......: <None>Measure Units ........: <None>XY Cluster Tolerance .: 2.0Spatial Index ........: parameter: SPIDX_RTREE exist: Yes array form: -2,0,0Layer Envelope .......: minx: 124236.00000, miny: 358722.32595 maxx: 173622.00000, maxy: 410100.75000Entities .............: pLayer Type ...........: In-Line Spatial TypeCreation Date ........: 08/23/10 17:16:35I/O Mode .............: NORMALAutolocking ..........: EnabledPrecision.............: BasicUser Privileges ......: SELECT, UPDATE, INSERT, DELETECoordinate System ....: UNKNOWNLayer Configuration ..: DEFAULTS
