I am able to add marker symbol in arcgis online web map but when i add marker symbol in arcgis online webapp it is not showing the marker on the map
Adding marker in web map link http://www.arcgis.com/home/webmap/viewer.html?marker=-123.065320;44.882852;;Race start and finish;;Grindstone 100 Ultra Marathon&level=7
this link works fine but when i add marker in webapp as below
http://www.arcgis.com/apps/Viewer/index.html?appid=daf7d40ac8a44a83a760995aecb1f446&marker=-123.065320;44.882852;;;;label
it did not display the marker
Plz help
the only solution I've found so far is to create a point feature class and publish it to AGO - then you can add it to your web map like any other layer
this isn't a great solution for a web map, tho, since the points would be static - you'd lose scalability in the web map unless you created a ton of points and gave them all different scale dependencies. Of course, that also depends on the scale of your other features as well as how many there are, etc.
I, too, would like to know the answer to this question. Have you found a solution?
