<?xml version="1.0" encoding="utf-8"?><mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Query, then zoom to results" styleName="plain"> <mx:Script> <![CDATA[ import com.esri.ags.geometry.Extent; import com.esri.ags.Graphic; import com.esri.ags.geometry.Polygon; import com.esri.ags.tasks.FeatureSet; import mx.controls.Alert; import mx.rpc.AsyncResponder; import mx.collections.ArrayCollection; import mx.managers.PopUpManager; import mx.managers.PopUpManagerChildList; import mx.events.ListEvent; private var highlightedGraphic:Graphic; [Bindable] private var lastIdentifyResultGraphic:Graphic; private function popupresult():void { var popData:DataPopup = new DataPopup; PopUpManager.addPopUp(popData,this,false,PopUpManagerChildList.POPUP); popData.MainMap = MainMap; popData.myGraphicsLayer= myGraphicsLayer; } private function onItemRollOver(event : ListEvent) : void { if (highlightedGraphic) { highlightedGraphic.symbol = resultsSymbol; } highlightedGraphic = findGraphicByAttribute(event.itemRenderer.data) highlightedGraphic.symbol = highlightSymbol; } public function findGraphicByAttribute(attributes : Object) : Graphic { for each( var graphic : Graphic in myGraphicsLayer.graphicProvider) { if ( graphic.attributes === attributes) { return graphic; } } return null; } private function sfDataGrid_Click():void { var obj:Object =popData.resultsGrid.selectedItem; if (obj != null) { lastIdentifyResultGraphic = null; query.where = "STATE_NAME = '" + obj["STATE_NAME"] + "'" queryTaskZoom.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { lastIdentifyResultGraphic = featureSet.features[0]; lastIdentifyResultGraphic.symbol = resultsSymbol; MainMap.extent = new Extent(lastIdentifyResultGraphic.geometry.extent.xmin,lastIdentifyResultGraphic.geometry.extent.ymin,lastIdentifyResultGraphic.geometry.extent.xmax,lastIdentifyResultGraphic.geometry.extent.ymax); } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString(), "Query Problem"); } } } private function doQuery():void { query.text = fText.text query.where = "" queryTask.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { // clear the graphics layer myGraphicsLayer.clear(); if (featureSet.features.length == 0) { Alert.show("No States found. Please try again."); } else { popupresult(); var unionExtent:Extent; var myFirstGraphic:Graphic = featureSet.features[0]; unionExtent = Polygon(myFirstGraphic.geometry).extent; for each (var myGraphic1:Graphic in featureSet.features) { myGraphicsLayer.add(myGraphic1); unionExtent = unionExtent.union(Polygon(myGraphic1.geometry).extent); } MainMap.extent = unionExtent; } } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString()); } } ]]> </mx:Script> <!-- Start Declarations --> <!-- Symbol for Query Result as Polygon --> <esri:SimpleFillSymbol id="resultsSymbol" color="0x999999" alpha="0.01" style="solid"> <esri:SimpleLineSymbol color="0x00FFFF" width="2" alpha="1" style="solid" /> </esri:SimpleFillSymbol> <esri:SimpleFillSymbol id="highlightSymbol" color="0xFF0000" outline="{borderSymbol}"/> <esri:SimpleLineSymbol id="borderSymbol" color="0x706D69" /> <!-- Layer with US States --> <esri:QueryTask id="queryTask" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/> <esri:QueryTask id="queryTaskZoom" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/> <esri:Query id="query" text="{fText.text}" returnGeometry="true" outSpatialReference="{MainMap.spatialReference}"> <esri:outFields> <mx:String>MED_AGE</mx:String> <mx:String>POP2007</mx:String> </esri:outFields> </esri:Query> <!-- End Declarations --> <mx:HBox width="100%" height="40" backgroundColor="0xDDDDFF" paddingTop="10" horizontalAlign="center"> <mx:Text text="Search for U.S. States:"/> <mx:TextInput id="fText" enter="doQuery()" text="Ca"/> <mx:Button label="Query" click="doQuery()"/> </mx:HBox> <mx:Text id="resultSummary" height="15"/> <mx:VDividedBox height="100%" width="100%"> <esri:Map id="MainMap"> <esri:extent> <esri:Extent xmin="-126" ymin="24" xmax="-67" ymax="50"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" symbol="{resultsSymbol}" graphicProvider="{lastIdentifyResultGraphic}"/> </esri:Map> <!--mx:DataGrid id="resultsGrid" click="sfDataGrid_Click()" itemRollOver="onItemRollOver(event)" dataProvider="{queryTask.executeLastResult.attributes}" scroll="true" width="100%" height="40%"/--> </mx:VDividedBox></mx:Application>
<?xml version="1.0" encoding="utf-8"?><mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="400" height="300" title="Results"><mx:Script> <![CDATA[ import mx.controls.DataGrid; import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.managers.PopUpManager; import com.esri.ags.Map; import com.esri.ags.layers.GraphicsLayer; [Bindable] public var MainMap:Map; [Bindable] public var myGraphicsLayer:GraphicsLayer; ]]></mx:Script> <mx:DataGrid id="resultsGrid" click="sfDataGrid_Click()" itemRollOver="onItemRollOver(event)" dataProvider="{queryTask.executeLastResult.attributes}" scroll="true" width="100%" height="40%"/></mx:TitleWindow>
