var statDef = new StatisticDefinition(); statDef.statisticType = "sum"; statDef.onStatisticField = "Area"; statDef.outStatisticFieldName = "Tot Area"; var query = new Query(); query.returnGeometry = false; query.where = "Area>0"; query.outFields = ["Area"]; query.outStatistics = [ statDef ]; query.groupByFieldsForStatistics = ["YearEstabl", "TypeName"]; query.orderByFields = ["YearEstabl", "TypeName"]; var qt = new QueryTask("http://services1.arcgis.com/Mpa25zPNMAT08GQg/ArcGIS/rest/services/AllPropertiesEstablished/FeatureServer/0"); qt.execute(query, function(result){ ... } });
Yes Jason, not seeing any other difference, other than Supports statistics......So rokitmaps, atleast you can give it a try by setting SupportsStatistics true for the layer.....
Interesting. This sample does use where clause for the statistical calculation, and it works. The main difference I can tell is the sample uses a feature layer that supports statistics, while rokitmaps uses a feature service.
statDef.outStatisticFieldName = "TotArea";
When using outStatistics the only other parameters that will be used are groupByFieldsForStatistics, orderByFields, text, time, and where.
