Hey Karen,
Have you found a solution for this? I'm having the same problem at the moment, how to import .class, .land elements into ArcGIS so that I can make a join to another table.
Do you find the solution? I also have the same problem.
The "Save Run As" button exports results as a "CLASS" file. If you open that in Notepad you will see it is actually just a CSV.
p.s. "class" is for class metrics, the same applies to others e.g. a landscape metric output has the extension "land"
