Unable to make a connection to ArcGIS Server in ArcCatalog. Received the following error message:
"We were unable to connect to: https://_____.____.com:6443/arcgis. Error: Slow down request rate. (status code 503)."
Hi Megan,
Are you able to connect to https://_____.____.com:6443/arcgis/manager successfully in a web browser?
Jake,
Thank you for your response. No I am not able to access the Server Manager. I receive the following message:
"This machine does not currently participate in ArcGIS Server site. You can either create a new site or join an existing site"
ArcGIS for Server was already installed and configured on this machine but doesn't seem to be working today.
Try restarting the ArcGIS Server service and then see if you are able to connect to ArcGIS Server Manager.
Could you walk me through how to do that? I appreciate the help.
If you are using :6443, use the <machine name> not the .com.
if using the .com, make sure you specify the web adaptor, which might not be the default "arcgis" if you set it up with a custom web adaptor (we usually change it, especially if creating multiple).
if you have the administering via the web adaptor turned off, which is recommended, you also will not be able to administer (and I think manage) thru the .com\webadaptor.
(Sorry, our network is down, so using my iPad To reply.)
The last time I saw something similar, ArcGIS Server was deployed on an NFS volume on a Linux box. Can you provide any details as to your implementation, specifically where your config-store is located? Like is it on a NAS/SAN device or similar?
I have encounter the same thing ,in my case the machine is joined to the domain but it is not able to retirve any service in the domain directory. whenver you create the site the site will be deleted automaticlly . This is releated to the VM , and user permission. Hope this is helpfull
thanks
Ramla
Consider omitting the port number on your address. ArcGIS Web Adaptor is normally used so you wouldn't have to, specifically for domain-wide accessible web servers that require secured connections.
It is possible to reach out to AGS servers via its web adaptor for administrative purposes. Depended upon how it's configured (or not), it is also possible to use the DNS alias with the port to connect to a server.
did you ever get this resolved? having the same issue
i have the same error and while i am trying to enter the join an exits website the arcgis show me this message "java.lang.NullPointerException"
