aspect.after(printMapTool._printButton, "openDropDown", function() { $('.dijitPopup.dijitMenuPopup').each(function() { $('#' + this.id).css('z-index', 2000); }); });
/**************************** Start Print Functions *****************************/ registry.byId("nav_print").on("click", function () { $("#printform").show(); } ); function createPrintDijit(printTitle, pageSize, pageOr) { var printURL = "http://192.168.20.14:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"; // create an array of objects that will be used to create print templates var layouts = [ { "name": pageSize +" "+ pageOr, "label": "Landscape (PDF)", "format": "pdf", "options": { "legendLayers": [], // empty array means no legend //"scalebarUnit": "Feet", "titleText": printTitle } } ]; // create the print templates, could also use dojo.map var templates = []; dojo.forEach(layouts, function(lo) { var t = new PrintTemplate(); t.layout = lo.name; t.label = lo.label; t.format = lo.format; t.layoutOptions = lo.options templates.push(t); }); printer = new Print({ "map": map, "templates": templates, url: printURL, }, dojo.byId("printMap")); printer.startup(); } // Create default print widget createPrintDijit("PWSB Emap", "Tabloid", "Landscape"); // Re-Create the print button when any of the form fields change registry.byId("pagetitle").on("change", function () { pageSize = registry.byId("pagesize").get("value"); pageOrient = registry.byId("pageor").get("value"); pageTitle = registry.byId("pagetitle").get("value"); printer.destroy(); console.log(pageTitle+" "+pageSize+" "+pageOrient); createPrintDijit(pageTitle, pageSize, pageOrient); } ); registry.byId("pagesize").on("change", function () { pageSize = registry.byId("pagesize").get("value"); pageOrient = registry.byId("pageor").get("value"); pageTitle = registry.byId("pagetitle").get("value"); printer.destroy(); console.log(pageTitle+" "+pageSize+" "+pageOrient); createPrintDijit(pageTitle, pageSize, pageOrient); } ); registry.byId("pageor").on("change", function () { pageSize = registry.byId("pagesize").get("value"); pageOrient = registry.byId("pageor").get("value"); pageTitle = registry.byId("pagetitle").get("value"); printer.destroy(); //createPrintDijit(pageTitle, pageSize, pageOrient); } ); /***************************** End Print Functions ******************************/
