Stace,
Using Desktop 10.2.2.
Any work around for this problem ? I am having problems with this. I have a AGOL feature service with attachments. Do not want to loose the link between the data and attachments. I am able to update values in a field and sync back to AGOL from desktop with no problem. Adding a field does not give me an error when I sync, it's just not visible in the AGOL feature service. So nothing happens. No new field added to the service.
How can I add fields, sync back to AGOL without publishing again ? If It wasn't for the attachments I would not have had a problem to replace, but this removes all the attachments.
Anybody with ideas or tips ?
Regards
Hi, did you ever find a solution? I guess you could edit the JSON
http://blogs.esri.com/esri/arcgis/files/2014/10/How-to-Update-Hosted-Feature-Service-Schemas1.pdf
I was able to change CVDs, but not add a field... Anyone have a work around?
For adding a new field to the existing service in AGOL map Go through following Steps
1. First Stop the Map Service from ArcGIS Server if the service is running.
2. Open the attribute table and add as much number of fields as you want.
3. Save the map document
4. Right click the map document in ArcCatalog Press Share as Service
5. Select Overwrite an existing service and publish the map document
6. Open AGOL web map and refresh the link or again add the rest url link
The data will be updated
