ITopologicalOperator2 pTopOp = pFeature.ShapeCopy as ITopologicalOperator2; IGeometry differenceGeometry = pTopOp.Difference(pSegment); pTopOp = differenceGeometry as ITopologicalOperator2; pTopOp.IsKnownSimple_2 = false; pTopOp.Simplify(); pFeature.Shape = pTopOp as IGeometry; pFeature.Store();
IMxDocument itfMxDoc; IMap pmap; IFeatureCursor itfCursor1; IFeatureCursor itfCursor2; IFeature itfFeature1; IFeature itfFeature2; IFeatureLayer pflayer1; IFeatureLayer pflayer2; itfMxDoc = m_application.Document as IMxDocument; pmap = itfMxDoc.FocusMap; pflayer1 = GetLayerByName("Shp1"); IFeatureSelection pFlSelection = pflayer1 as IFeatureSelection; // get index from selected feature //but I will not select anything IEnumIDs itfListId = pFlSelection.SelectionSet.IDs; itfListId.Reset(); int Index = itfListId.Next(); itfFeature1 = pflayer1.FeatureClass.GetFeature(Index); // get your buffer ITopologicalOperator pTopo = itfFeature1.ShapeCopy as ITopologicalOperator; IPolygon pPolygon = pTopo.Buffer(1) as IPolygon; pflayer2 = GetLayerByName("Shp2"); ISpatialFilter itfFilter; itfFilter = new SpatialFilter(); itfFilter.Geometry = pPolygon as IGeometry; itfFilter.GeometryField = pflayer2.FeatureClass.ShapeFieldName; itfFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelEnvelopeIntersects; // get your points inside your buffer itfCursor2 = pflayer2.FeatureClass.Search(itfFilter, false); itfFeature2 = itfCursor2.NextFeature(); // Loop for each point in your buffer while (itfFeature2 != null) { // Get feature id from each feature to select later. itfFeature2 = itfCursor2.NextFeature(); }
//before loop int equalFieldCount = 0; // in the loop bool equal = Object.Equal(pfeature1.getValue(i), pfeature2.getValue(i)) if(equal)[INDENT] equalFieldCount++; [/INDENT]// after loop bool allFieldsAreEqual = false; if(pfeature.fields.fieldsCount - "numberOfGeometryFields" == equalFieldCount)[INDENT] allFieldsAreEqual = true; [/INDENT]
public override void OnClick() { IFeatureLayer pflayer1; IFeatureLayer pflayer2; IFeature featureA; IFeature featureB; pflayer1 = GetLayerByName("Shape1"); IFeatureSelection p1FlSelection = pflayer1 as IFeatureSelection; int[] idList = GetFidList(@D:\ShapeFile1).ToArray(); IFeatureCursor feature1Cursor = pflayer1.FeatureClass.GetFeatures(idList, false); featureA = feature1Cursor.NextFeature(); pflayer2 = GetLayerByName("Shape2"); int[] oidList = GetFidList(@D:\ShapeFile1).ToArray(); IFeatureCursor feature2Cursor = pflayer2.FeatureClass.GetFeatures(oidList, false); featureB = feature2Cursor.NextFeature(); List<int> fidList = new List<int>(); while (featureA != null) { while (featureB != null) { string risultato = FeaturesEqual(featureA, featureB); if (!String.IsNullOrEmpty(risultato)) fidList.Add(Convert.ToInt32(risultato)); featureB = feature2Cursor.NextFeature(); } feature2Cursor = pflayer2.FeatureClass.GetFeatures(oidList, false); featureB = feature2Cursor.NextFeature(); feature1Cursor = pflayer1.FeatureClass.GetFeatures(idList, false); featureA = feature1Cursor.NextFeature(); } //At this point it stops and leaves string elenco = String.Empty; foreach (int numero in fidList) { elenco += numero + ","; } elenco = elenco.Trim(','); IMap pMap = m_hookHelper.FocusMap; IActiveView pActiveView = (IActiveView)m_hookHelper.FocusMap; string where = "FID IN (" + elenco + ")"; SelectMapFeaturesByAttributeQuery(pActiveView, pflayer1, where); }
//Compare Features //temporarily I consider only attribute compare and not geometry public string FeaturesEqual(IFeature pFeatureA, IFeature pFeatureB) { // attribute equal test int diffCount = 0; for (int i = 2; i < pFeatureA.Fields.FieldCount; i++) { string valore1 = pFeatureA.get_Value(i).ToString(); string valore2 = pFeatureB.get_Value(i).ToString(); bool equal = ESRI.ArcGIS.Geodatabase.Object.Equals(pFeatureA.get_Value(i), pFeatureB.get_Value(i)); if (!equal) { diffCount++; } if (diffCount > 0) return pFeatureA.OID.ToString(); } return String.Empty; //// geometry equal test //IArea pAreaA = pFeatureA.Shape as IArea; //IArea pAreaB = pFeatureB.Shape as IArea; //if (pAreaA.Area != pAreaB.Area) //{ // diffCount++; //} //if (diffCount > 0) //{ // return false; //} //return true; } public static List<int> GetFidList(string path) { List<int> fidList = new List<int>(); String shapefileStringTemplate = "Provider=ESRI.GeoDB.OleDB.1;Data Source={0};" + "Extended Properties=workspacetype=esriDataSourcesFile.ShapefileWorkspaceFactory.1;Geometry={1}"; String connectionString = String.Format(shapefileStringTemplate, path, "Fabbricati"); OleDbConnection myOleDbConnection = new OleDbConnection(connectionString); OleDbCommand command = myOleDbConnection.CreateCommand(); command.CommandType = CommandType.Text; command.CommandText = String.Format(@SELECT FID FROM FABBRICATI); try { myOleDbConnection.Open(); OleDbDataReader reader = command.ExecuteReader(); while (reader.Read() == true) { fidList.Add( Convert.IsDBNull(reader["FID"]) ? 0 : Convert.ToInt32(reader["FID"]) ); } reader.Close(); return fidList; } catch (Exception) { throw; } finally { if (myOleDbConnection.State != ConnectionState.Closed) myOleDbConnection.Close(); } }
public override void OnClick() { // i will reuse cursor false-> true IFeatureCursor feature1Cursor = pflayer1.FeatureClass.GetFeatures(idList, true); while (featureA != null) { // queryin again with same params makes forever loop // using only first feature from an array feature1Cursor = pflayer1.FeatureClass.GetFeatures(idList, true); featureA = feature1Cursor.NextFeature(); } //At this point it stops and leaves // because your code is not in try catch block and exception occured string elenco = String.Empty;
public string FeaturesEqual(IFeature pFeatureA, IFeature pFeatureB) { // if value is null you have exception use Convert.ToSring(pFeatureA.get_Value(i)); string valore1 = pFeatureA.get_Value(i).ToString(); // I intend to use System.Object.Equals didn't use ESRI's object before bool equal = ESRI.ArcGIS.Geodatabase.Object.Equals(pFeatureA.get_Value(i), pFeatureB.get_Value(i)); }
