Hello,I want to change the geometry (textpath) of existing annotation features so that the curvature gets horizontal. I tried several things but did not succeed.Can somebody help me with the code i already have? Set pFeatureCursor = pFeatureclass.Update(pFilter, False) Set pFeature = pFeatureCursor.NextFeature While Not pFeature Is Nothing Dim pAnnoFeat As IAnnotationFeature Set pAnnoFeat = pFeature Dim pElement As IElement Set pElement = pAnnoFeat.Annotation Dim pTextElement As ITextElement Set pTextElement = pElement Dim pTextSym As ISimpleTextSymbol Set pTextSym = pTextElement.Symbol If Not pTextSym Is Nothing Then Dim pTextPath As ITextPath Set pTextPath = pTextSym.TextPath If TypeOf pTextPath Is IOverposterTextPath Then If TypeOf pElement.Geometry Is IPolyline Then Dim pPointCol As IPointCollection Set pPointCol = New Polyline Set pPointCol = pElement.Geometry ' Just keep start- and endpoint pPointCol.RemovePoints 1, pPointCol.PointCount - 2 '....... Replace textPath here ...... pFeatureCursor.UpdateFeature pFeature End If End If End If Set pFeature = pFeatureCursor.NextFeature Wend End If
Greetings, Henk
