' This snippet is intended to be inserted at the base level of a Class. ' It is not intended to be nested within an existing Function or Sub. ' '''<summary>Deletes from a specified directory that match a certain pattern.</summary> ''' '''<param name="filePath">A System.String that is the file and path from where to delete files. Example: "C:\temp"</param> '''<param name="pattern"> A System.String that is the pattern for files to delete. Example: "*.txt" or "myfile.*" or "*.*"</param> ''' '''<remarks>All files meeting the pattern will be deleted from the specified directory.</remarks> Public Sub DeleteFilesFromDir(ByVal filePath As System.String, ByVal pattern As System.String) Dim directoryInfo As System.IO.DirectoryInfo = New System.IO.DirectoryInfo(filePath) Dim files As System.IO.FileInfo() = directoryInfo.GetFiles(pattern) For Each file As System.IO.FileInfo In files file.Delete() Next End Sub
Private Sub DeleteDataset() Dim pMxDocument As IMxDocument Dim pMap As IMap Dim pFeatureLayer As IFeatureLayer Dim pFeatureClass As IFeatureClass Dim pDataset As IDataset Dim pActiveView As IActiveView Set pMxDocument = ThisDocument Set pMap = pMxDocument.FocusMap ' Define the dataset to be deleted. Set pFeatureLayer = pMap.Layer(0) Set pFeatureClass = pFeatureLayer.FeatureClass ' Remove the layer from the active map. pMap.DeleteLayer pFeatureLayer ' Delete the dataset. Set pDataset = pFeatureClass pDataset.Delete ' Refresh the map. Set pActiveView = pMap pActiveView.Refresh End Sub
