Have you looked the following? It looks promising...http://www.codeproject.com/KB/silverlight/SilverlightDataGridExport.aspxHere is another post: http://www.codeproject.com/KB/silverlight/SL4InteropWithExcel.aspxHope these help.
public static class DataGridExtensions { public static void Export(this DataGrid dg, List<string> excludedColumns, Dictionary<string, string> aliases) { ExportDataGrid(dg, excludedColumns, aliases); } public static void ExportDataGrid(DataGrid dGrid, List<string> excludedColumns, Dictionary<string, string> aliases) { SaveFileDialog objSFD = new SaveFileDialog() { DefaultExt = "csv", Filter = "CSV Files (*.csv)|*.csv|Excel XML (*.xml)|*.xml|All files (*.*)|*.*", FilterIndex = 1 }; if (objSFD.ShowDialog() == true) { string strFormat = objSFD.SafeFileName.Substring(objSFD.SafeFileName.IndexOf('.') + 1).ToUpper(); StringBuilder strBuilder = new StringBuilder(); if (dGrid.ItemsSource == null) return; List<string> lstFields = new List<string>(); if (dGrid.HeadersVisibility == DataGridHeadersVisibility.Column || dGrid.HeadersVisibility == DataGridHeadersVisibility.All) { foreach (DataGridColumn dgcol in dGrid.Columns) { if (excludedColumns != null) { foreach (string columnName in excludedColumns) { if (dgcol.Header.ToString() == columnName) { continue; } else { lstFields.Add(FormatField(dgcol.Header.ToString(), strFormat)); } } } else lstFields.Add(FormatField(dgcol.Header.ToString(), strFormat)); } BuildStringOfRow(strBuilder, lstFields, strFormat); } foreach (Graphic data in dGrid.ItemsSource) { lstFields.Clear(); foreach (DataGridColumn col in dGrid.Columns) { string strValue = string.Empty; string dataField = string.Empty; foreach (KeyValuePair<string, string> kv in aliases) { if (col.Header.ToString() == kv.Value) { dataField = kv.Key; break; } } if (excludedColumns != null) { foreach (string columnName in excludedColumns) { if (col.Header.ToString() == columnName) continue; else strValue = data.Attributes[dataField].ToString(); } } else strValue = data.Attributes[dataField].ToString(); lstFields.Add(FormatField(strValue, strFormat)); } BuildStringOfRow(strBuilder, lstFields, strFormat); } StreamWriter sw = new StreamWriter(objSFD.OpenFile()); if (strFormat == "XML") { //Let us write the headers for the Excel XML sw.WriteLine("<?xml version=\"1.0\" encoding=\"utf-8\"?>"); sw.WriteLine("<?mso-application progid=\"Excel.Sheet\"?>"); sw.WriteLine("<Workbook xmlns=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<DocumentProperties xmlns=\"urn:schemas-microsoft-com:office:office\">"); sw.WriteLine("<Author>Arasu Elango</Author>"); sw.WriteLine("<Created>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</Created>"); sw.WriteLine("<LastSaved>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</LastSaved>"); sw.WriteLine("<Company>Atom8 IT Solutions (P) Ltd.,</Company>"); sw.WriteLine("<Version>12.00</Version>"); sw.WriteLine("</DocumentProperties>"); sw.WriteLine("<Worksheet ss:Name=\"Silverlight Export\" xmlns:ss=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<Table>"); } sw.Write(strBuilder.ToString()); if (strFormat == "XML") { sw.WriteLine("</Table>"); sw.WriteLine("</Worksheet>"); sw.WriteLine("</Workbook>"); } sw.Close(); } } private static void BuildStringOfRow(StringBuilder strBuilder, List<string> lstFields, string strFormat) { switch (strFormat) { case "XML": strBuilder.AppendLine("<Row>"); strBuilder.AppendLine(String.Join("", lstFields.ToArray())); strBuilder.AppendLine("</Row>"); break; case "CSV": strBuilder.AppendLine(String.Join(",", lstFields.ToArray())); break; } } private static string FormatField(string data, string format) { switch (format) { case "XML": return String.Format("<Cell><Data ss:Type=\"String\">{0}</Data></Cell>", data); case "CSV": return String.Format("\"{0}\"", data.Replace("\"", "\"\"\"").Replace("\n", "").Replace("\r", "")); } return data; } }
YourNamespace.DataGridExtensions.ExportDataGrid(theGrid, null, aliases);
Hi Russel, I have used the first link to export DataGrid to Excel.I have modified the code to work for Graphics data. public static class DataGridExtensions { public static void Export(this DataGrid dg, List<string> excludedColumns, Dictionary<string, string> aliases) { ExportDataGrid(dg, excludedColumns, aliases); } public static void ExportDataGrid(DataGrid dGrid, List<string> excludedColumns, Dictionary<string, string> aliases) { SaveFileDialog objSFD = new SaveFileDialog() { DefaultExt = "csv", Filter = "CSV Files (*.csv)|*.csv|Excel XML (*.xml)|*.xml|All files (*.*)|*.*", FilterIndex = 1 }; if (objSFD.ShowDialog() == true) { string strFormat = objSFD.SafeFileName.Substring(objSFD.SafeFileName.IndexOf('.') + 1).ToUpper(); StringBuilder strBuilder = new StringBuilder(); if (dGrid.ItemsSource == null) return; List<string> lstFields = new List<string>(); if (dGrid.HeadersVisibility == DataGridHeadersVisibility.Column || dGrid.HeadersVisibility == DataGridHeadersVisibility.All) { foreach (DataGridColumn dgcol in dGrid.Columns) { if (excludedColumns != null) { foreach (string columnName in excludedColumns) { if (dgcol.Header.ToString() == columnName) { continue; } else { lstFields.Add(FormatField(dgcol.Header.ToString(), strFormat)); } } } else lstFields.Add(FormatField(dgcol.Header.ToString(), strFormat)); } BuildStringOfRow(strBuilder, lstFields, strFormat); } foreach (Graphic data in dGrid.ItemsSource) { lstFields.Clear(); foreach (DataGridColumn col in dGrid.Columns) { string strValue = string.Empty; string dataField = string.Empty; foreach (KeyValuePair<string, string> kv in aliases) { if (col.Header.ToString() == kv.Value) { dataField = kv.Key; break; } } if (excludedColumns != null) { foreach (string columnName in excludedColumns) { if (col.Header.ToString() == columnName) continue; else strValue = data.Attributes[dataField].ToString(); } } else strValue = data.Attributes[dataField].ToString(); lstFields.Add(FormatField(strValue, strFormat)); } BuildStringOfRow(strBuilder, lstFields, strFormat); } StreamWriter sw = new StreamWriter(objSFD.OpenFile()); if (strFormat == "XML") { //Let us write the headers for the Excel XML sw.WriteLine("<?xml version=\"1.0\" encoding=\"utf-8\"?>"); sw.WriteLine("<?mso-application progid=\"Excel.Sheet\"?>"); sw.WriteLine("<Workbook xmlns=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<DocumentProperties xmlns=\"urn:schemas-microsoft-com:office:office\">"); sw.WriteLine("<Author>Arasu Elango</Author>"); sw.WriteLine("<Created>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</Created>"); sw.WriteLine("<LastSaved>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</LastSaved>"); sw.WriteLine("<Company>Atom8 IT Solutions (P) Ltd.,</Company>"); sw.WriteLine("<Version>12.00</Version>"); sw.WriteLine("</DocumentProperties>"); sw.WriteLine("<Worksheet ss:Name=\"Silverlight Export\" xmlns:ss=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<Table>"); } sw.Write(strBuilder.ToString()); if (strFormat == "XML") { sw.WriteLine("</Table>"); sw.WriteLine("</Worksheet>"); sw.WriteLine("</Workbook>"); } sw.Close(); } } private static void BuildStringOfRow(StringBuilder strBuilder, List<string> lstFields, string strFormat) { switch (strFormat) { case "XML": strBuilder.AppendLine("<Row>"); strBuilder.AppendLine(String.Join("", lstFields.ToArray())); strBuilder.AppendLine("</Row>"); break; case "CSV": strBuilder.AppendLine(String.Join(",", lstFields.ToArray())); break; } } private static string FormatField(string data, string format) { switch (format) { case "XML": return String.Format("<Cell><Data ss:Type=\"String\">{0}</Data></Cell>", data); case "CSV": return String.Format("\"{0}\"", data.Replace("\"", "\"\"\"").Replace("\n", "").Replace("\r", "")); } return data; } }And then in your Export button click event handler call this method:YourNamespace.DataGridExtensions.ExportDataGrid(theGrid, null, aliases);Where:- theGrid is the DataGrid with the data to be exported- null is for excludedColumns (I just needed to not export some of the columns)- aliases is a Dictionary<string, string>, where the key is the real Field Name, and value is the Field Alias that I have used to display in the DataGrid headersGood Luck!
//The parameter "aliases" is a Dictonary<string, string> and you can hardcode it, //get the data form XML config file, or from a database. //Here is how you can create it: Dictionary<string, string> aliases = new Dictionary<string, string>(); aliases.Add("OriginalFieldName1", "FieldNameAlias1"); aliases.Add("OriginalFieldName2", "FieldNameAlias2"); aliases.Add("OriginalFieldName3", "FieldNameAlias3"); aliases.Add("OriginalFieldName4", "FieldNameAlias4");
foreach (Graphic data in dGrid.ItemsSource) { lstFields.Clear(); foreach (DataGridColumn col in dGrid.Columns) { string strValue = string.Empty; string dataField = string.Empty; // Add this if statement if (aliases == null) { dataField = col.Header.ToString(); } else { foreach (KeyValuePair<string, string> kv in aliases) { if (col.Header.ToString() == kv.Value) { dataField = kv.Key; break; } } } // End if statement if (excludedColumns != null) { foreach (string columnName in excludedColumns) { if (col.Header.ToString() == columnName) continue; else strValue = data.Attributes[dataField].ToString(); } } else strValue = data.Attributes[dataField].ToString(); lstFields.Add(FormatField(strValue, strFormat)); } BuildStringOfRow(strBuilder, lstFields, strFormat); }
YourNamespace.DataGridExtensions.ExportDataGrid(theGrid, null, null);
I don't have time to do any testing, but try to add the "if statement" below, and see if it will work with no aliases (see the comments):
Hi Russel,I am using the aliases to show more meaningful field names in DataGrids, MapTips, ...//The parameter "aliases" is a Dictonary<string, string> and you can hardcode it, //get the data form XML config file, or from a database. //Here is how you can create it: Dictionary<string, string> aliases = new Dictionary<string, string>(); aliases.Add("OriginalFieldName1", "FieldNameAlias1"); aliases.Add("OriginalFieldName2", "FieldNameAlias2"); aliases.Add("OriginalFieldName3", "FieldNameAlias3"); aliases.Add("OriginalFieldName4", "FieldNameAlias4"); This will only work though if your DataGrid has the same aliases as headers.And here is where my code doesn't work, because I always use Aliases, and I did not cover the scenario when Aliases are not used. (Sorry, my bad).I don't have time to do any testing, but try to add the "if statement" below, and see if it will work with no aliases (see the comments): foreach (Graphic data in dGrid.ItemsSource) { lstFields.Clear(); foreach (DataGridColumn col in dGrid.Columns) { string strValue = string.Empty; string dataField = string.Empty; // Add this if statement if (aliases == null) { dataField = col.Header.ToString(); } else { foreach (KeyValuePair<string, string> kv in aliases) { if (col.Header.ToString() == kv.Value) { dataField = kv.Key; break; } } } // End if statement if (excludedColumns != null) { foreach (string columnName in excludedColumns) { if (col.Header.ToString() == columnName) continue; else strValue = data.Attributes[dataField].ToString(); } } else strValue = data.Attributes[dataField].ToString(); lstFields.Add(FormatField(strValue, strFormat)); } BuildStringOfRow(strBuilder, lstFields, strFormat); }Then you can change the call:YourNamespace.DataGridExtensions.ExportDataGrid(theGrid, null, null);And you can do this if your DataGrid displays the real field names. If the code fix doesn't work, try creating the aliases parameter with the same OriginalFieldName and FieldNameAlias just to see if it will work. I will go back and simplify this method when I get a chance. Gotta go! Good Luck!
