Hi Brian, http://www.arcgis.com/sharing/rest/content/items/<itemId>/data works for me for PDF items shared with everyone, where the item ID comes from the URL of the ArcGIS Online item, e.g., http://<organization>.maps.arcgis.com/home/item.html?id=7e92720c9f264cd6b07c247c2e43b06 Mike
Hi Bradley,
Did you identify a solution for this. We're trying to do the same thing right now. We have the option to host linked content outside of AGO but it's easier for our users if we can do it all within the AGO platform
Has there been any update to this? It is 2017. I too am trying to open a file (pdf) stored on AGOL through a hypelink url within a web app. From what I can see is there is two options.
It sure would be nice to be able to directly link to content published within an organization. For now I'm going to have to default to using option number 2 though this seems a bit silly being the fact that all the other functionality is there within AGOL other than directly opening the file.
Same request as what John suggests above, but for Portal for ArcGIS. If the user is logged into Portal already (via a separate tab even) then why would a direct link to the resource data not work?
Has anyone found a solution to this issue?We cannot find an answer to the questions raised here anywhere.
Thanks.
Still no solution to this? Really?
Any ideas from anyone?
Is this on the GIS ideas board? Or under development? Looking for a pdf added to On-Premise Portal to have a link *to the document itself* that is accessible to users when the item is only shared to the Organization.
I also have this same question. Any update on this Esri?
Specifically, if I have an image, pdf, or spreadsheet to link to from a Dashboard or StoryMap. If that item is shared with my organization, how can I insert the item as a rest url to link directly to the document. Not to the item details page. That is just confusing for users.
From what I've seen the item has to be shared publicly (which is not an option for my organization and I would assume for others) in order to have the rest url at the bottom right of the item details page. If that is available, then this wouldn't be an issue.
Anyone else have suggestions?
Here looking for the same functionality from our Portal as everyone else. I've got two as-builts I want to load as PDF items, giving me a hyperlink I can add to features for users to open the PDF directly in the field. I can do this only if the item is shared as Public, otherwise run into token issues.
