Is it possible to print my current MapView with all features, layers, etc. to a larger resolution plotter? I have not seen examples of doing so online. I am looking to do this via the WPF SDK.
For ArcGIS Runtime SDK for WPF we had a couple of printing samples:
Client-side printing: ArcGIS Runtime SDK for WPF Samples
Export Webmap: ArcGIS Runtime SDK for WPF Samples
Cheers
Mike
This points to another issue that I'm having. How do I search for questions on just 10.2.7? If I look for question on the SDK for .NET then I see answers that are relevant only to version 100 which works very differently from 10.2.7. I'm just having a hard time learning where to start with all of this. This really isn't related to the original post so my apologies for that but I'm not sure where to ask such things.
Yes Mike. I did mean the 10.2.7 version. Thanks for pointing me to those samples.
So one thing that I've seen done by some control vendors is that they'll have some control that is used consistently across their web site to display the version of subject. This is used in the forums and documentation to make it very clear what version is being talked about. There should be some easy way to navigate between the versions as well. So for the documentation area you might have a dropdown/combobox that lets you select the version. I'm very new to ArcGIS and it took me a while to figure out just how different the available versions were. Your response made it sound as if 10.2.7 was significantly different from 10.2.5. Is that the case? I just wasn't expecting a revision difference to have very different sample code hence my bundling of the minor versions together with "10.2.x".
Hi David,
When you say "10.2.x", do you mean ArcGIS Runtime SDK for .NET 10.2.7? In which case, I can move this post to the .NET SDK forum and remove my answer above (those samples are for the older (and retired) ArcGIS Runtime SDK for WPF 10.2.5).
Thanks for the feedback on accessing the 10.2.x samples. Assuming you mean 10.2.7, there are two ways to access them:
Release: Release Samples for v10.2.7 Release · Esri/arcgis-runtime-samples-dotnet · GitHub
Branch: GitHub - Esri/arcgis-runtime-samples-dotnet at 10.2.7
If you feel there would be a better/easier way for us to provide access to samples for previous versions of our SDKs we would greatly appreciate your feedback.
Thanks Mike. I started out looking at version 100 but it appears that it is still missing quite a few features. And getting to the 10.2.x examples isn't very straightforward. Every time I searched I found example code for version 100. I think I'm going to have to stick with 10.2.x for now.
