Hi Gustavo.I spent many hours trying to get the sync process to work properly and worked with the tech support folks in ESRI.I gave up since everything we tried would not work and I also put in a bug report to see if this could be worked on as a fix for 10.1 release. I read on their bug fix report that a number of issues with the sync process was fixed at 10.1 and I plan to get that install soon to test it out.
Hello Gustavo,Have you reviewed the Help topics for ArcPad Extension for ArcGIS Server? Also we have a tutorial, Publishing ArcPad data to ArcGIS Server that takes you through each step of the process and have Common problems and solutions troubleshooting page.At the end of the process, an .apo file is created alongside your ArcMap .mxd document. You use the .mxd and .apo together to create an ArcPad publication when publishing the ArcPad project to ArcGIS Server. Depending on where you have installed ArcGIS Server 10, the ArcPad files are typically found in this folder path - C:\Server\arcgisserverOutput\arcpadpublications.Hope this helps to get you started. If you should still need assistance, please submit a support request with Esri Support so you can work with an ArcPad specialist to resolve this challenge.Cheers,Denise
