Were you able to find anything else on this issue. I am running into the same issue. Any PDF over 5Mb will not open from the web browsers REST end point. It is odd and only appears to be happening to PDFs. I can open a JPEG that is greater than 5Mb in size and it opens no problem.
Thanks.
Was anyone ever able to find a solution to this problem?
do you find that they all do not open, or only some over a certain size?
I recently discovered that good PDFs in my geodatabase attachments will not open in a web browser from the rest end point if they are over a certain size (somewhere around 5Mb).
I'm not certain if this is something I need to adjust on my web server or within the rest endpoint configuration.
I know this is old, but any resolution. Having the same problem with tiff files. some open, some don't.
We are adding pdf attachments to a geodatabase. After adding several new features and attaching the corresponding pdf to the record, we've noticed that random attachments will not open. When the map feature is identified or when the attachment manager is opened from the attribute table, it displays the pdf in the attachment manager...like it is there...but will not open. We can remove the attachment and add it back and it will open. When we initially add them and test them, they work. But as we add more to the database, some of the attachments randomly stop working and have to be removed and re-added.... Any advice?
