i have created my new app by flex viewer, but the real challenge is to how to convert align text from left to right, in (search, layer list, query...etc) widget,...
Are you using the appbuilder to create your app or just configuring the xml files? If so, I think it should just work. See for example the Arabic example at http://resources.arcgis.com/en/help/flex-viewer/live/index_ar.htmlIf you are compiling the source code yourself: did you follow the steps at http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Localization/01m300000008000000/You might want to look in the HTML file for the above example and the config file for it:view-source:http://resources.arcgis.com/en/help/flex-viewer/live/index_ar.htmlhttp://resources.arcgis.com/en/help/flex-viewer/live/apps/ar/config.xml
