When i try to load a map into ExB (Dev edition) i get an error and the map doesn't load. The map is located on our our Portal. The error shown is the following:
Can someone point me to any direction of why this is happening?
Best regards
Kamran
Hi Kamran,
If the map widget loads with no issues but breaks only when attaching your own map, it might be a compatibility issue. This error could be caused from many reasons, but if you're working with your internal Portal, you should know that ExB supports only version 10.6 and above.
Shay.
