My values are padded with spaces. Sometimes it's "1", sometimes it's " 1" sometimes its "1 ".
I need to remove all the spaces before, between, after, wherever they appear...
Thanks!!!!
For leading and trailing whitespace, I would recommend using Python String strip() Method
Here's an example:
For any and all spaces, try replace:
Thanks, Chris. I need to use it in the Model. I am not familiar how I can add this to the model... Is there any way to do it with Field Calculator?
Sure, here's an example in the model (for replace):
This tool is available under...
>> Data Management Tools
>> Fields
>> Calculate Field
Chris, it works but I get zeros for some of the values..
For example, before I had "B", " B", "000B2"
After calculation I get: "B", "000B", "000B2"
I don't want it to be "000B"
For the rest of the records it worked fine
