sr = arcpy.SpatialReference() sr.factoryCode = 32759 # case sensitive sr.create() # essential step that is non-intuitive! print sr.name # to check
import arcpy from arcpy import env env.overwriteOutput = True prjFile = r"C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj" spatRef = arcpy.SpatialReference(prjFile) # list each raster and extract coordinates env.workspace = r"C:\temp\python\rasters" lstRasters = arcpy.ListRasters("*", "TIF") for ras in lstRasters: rasName = ras.split('.')[0] lat_lon = rasName.split('_')[1] if 'N' in lat_lon: lat = int(lat_lon[1:3]) else: lat = int(lat_lon[1:3]) * -1 if 'W' in lat_lon: lon = int(lat_lon[4:]) * -1 else: lon = int(lat_lon[4:]) # Create a point based on the coordinate values point = arcpy.Point(lon, lat) UTMfc = r"C:\TEMP\Python\UTM.shp" # create an empty point feature class with a field called 'Name' env.workspace = r"C:\temp\python\test.gdb" arcpy.CreateFeatureclass_management(env.workspace, "LatLon", "POINT", "", "", "", spatRef) arcpy.AddField_management("LatLon", "Name", "TEXT") # Populate the feature class with the coordinate value and the raster name rows = arcpy.InsertCursor("LatLon") row = rows.newRow() row.Name = rasName row.Shape = point rows.insertRow(row) del row, rows # Perform an intersect to find which zone the raster falls in arcpy.Intersect_analysis(["LatLon", UTMfc], "Intersect", "", "", "POINT") rows = arcpy.SearchCursor("Intersect") for row in rows: print str(row.Name) + " is in zone UTM" + str(row.Zone) arcpy.Delete_management("LatLon") arcpy.Delete_management("Intersect")
