I am trying to take these attached addresses and map them within the polygons from this link: Pennsylvania Spatial Data Access | Data Summary. I want to create a hot spot map where each polygon is color coded to reflect the amount of values counted within that polygon.
Essentially, this is what I want my map to look like. How can I create this?
I tried spatial joins, but my .csv data doesn't match any of the data in the shape file.
No, it looks like the polygons are an intptlat, intptlon while my data is on an x,y. Is that what you mean?
I you have an output featureclass, is it in the same coordinate system as the polygons?
It won't spatial join unless the coordinate system is the same (you will need to use the Project Tool in arctoolbox to finish this)
I have the addresses geocoded, but I can't seem to perform a spatial join.
address have to be geocoded,
I suspect the tutorial would be a good place to start
Tutorial: Geocode a table of addresses—ArcGIS Pro | ArcGIS Desktop
