So I'm relatively new to this but I'm trying to create a simple button through a Python Addin that will turn a layer on or off. I can get the layer to turn on, but not off when I reclick the same button. I figured that if I used the self.checked property for the buttonit would work but then I got the [Missing] Error indicating my syntax was bad. Idle was referencing the = sign I used in the If/Else statement when I went to perform the action based off of the property value. Here's the code that gave me the [Missing] error:import arcpy import pythonaddins class Toggle_Cust(object): """Implementation for C1_Cust.button (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): #Get the current Map Document and Create the Layer Index. mxd = arcpy.mapping.MapDocument("Current") COF_Customers = arcpy.mapping.ListLayers (mxd) [1] #Turn the Layer On or Off depending on property value if self.checked = True: COF_Customers.visible = True arcpy.RefreshActiveView() print "Customers On!" else: COF_Customers.visible = False arcpy.RefreshActiveView() print "Customers Off!" So just to test the premise I just tried turning on the layer withimport arcpy import pythonaddins class Toggle_Cust(object): """Implementation for C1_Cust.button (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): #Get the current Map Document and Create the Layer Index. mxd = arcpy.mapping.MapDocument("Current") lyrlist = arcpy.mapping.ListLayers (mxd) [0] #Identify the Customer Layer by Index Value COF_Customers = arcpy.mapping.ListLayers (mxd) [1] COF_Customers.visible = True arcpy.RefreshActiveView() print "Customers On!" That works to just turn on the layer. Anyone got any advice on turning the layer back off with another click of the same button?
