Since IOS 10 user-scalable=no no longer works in the viewport meta tag.
This obviously breaks maps as pinch zooming zooms the whole page, not just the map.
I couldn't find any workarounds - does anyone have any?
Nick
Hi Nick,
I have the same behavior with Api v4 and iOS 10... After looking at others smart mapping API :-), they use a listener on the documentElement to catch the zoomPinch and double tap events and stop them.
A guy post a similar solution on StackOverflow and you could easily implement it in a dojo module like that :
SO link : http://stackoverflow.com/a/38573198/3366795
Sample dojo module :
/** * Created by tony on 28/11/2016. */ define([ "dojo/sniff", "dojo/domReady!" ], function ( sniff ) { if (sniff('ios')) { //Disable pinch zoom on document document.documentElement.addEventListener('touchstart', function (event) { if (event.touches.length > 1) { event.preventDefault(); } }, false); //Disable double tap on document var lastTouchEnd = 0; document.documentElement.addEventListener('touchend', function (event) { var now = (new Date()).getTime(); if (now - lastTouchEnd <= 300) { event.preventDefault(); } lastTouchEnd = now; }, false); } }); //# sourceURL=vmv/mobileBehaviors.js
Good luck !
Hi Tony,
Just had a chance to try this out and it is working well, thanks again!
I also have an absolutely positioned menu system on top of the map. I added the below to stop the menus from bouncing around when panning the map.
<SPAN class="comment token">//disable scroll on the map containers so the menu doesn't bounce around when panning the map</SPAN> <SPAN class="keyword token">let</SPAN> mapContainers <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">querySelector</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">".view"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> mapContainers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'touchmove'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> event<SPAN class="punctuation token">.</SPAN><SPAN class="token function">preventDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks heaps for this! I'll give it a try when I get a chance and report back how it goes.
