<?xml version="1.0" ?> <!-- See Enhanced Search Widget XML Configuration.pdf for detailed explanation --> <configuration> <layers> <layer> <definitionexpression></definitionexpression> <enableexport>false</enableexport> <name>Traffic Cameras</name> <url>http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/MapServer/2</url> <expressions> <expression alias="Traffic Camera Description" textsearchlabel="Search Traffic Cameras by Location..."> <values> <value prompt="Example: I-71" userlist="I-71,I-64">upper(DESCRIPTION) LIKE upper('[value]%')</value> </values> </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select Traffic Cameras</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>DESCRIPTION</titlefield> <fields all="false"> <field name="DESCRIPTION" alias="Description" gridfield="true" /> <field name="URL" alias="Show Image" hyperlinkgridfield="true" hyperlinkaliastext="Get Traffic Image" visible="false" /> <field name="ONLINE" alias="Online" gridfield="true" gridfieldonly="false" /> <field name="LAST_UPDATED" alias="Last Updated" gridfield="true" gridfieldonly="false" dateformat="MM/DD/YYYY" useutc="true" /> </fields> <links> <link alias="View Traffic Photo"> <![CDATA[{URL}]]> <icon><![CDATA[assets/images/i_camera.png]]></icon> </link> </links> <zoomscale>5000</zoomscale> <queryattachments>false</queryattachments> </layer> </layers> <tables /><!-- This section is ONLY for tables (i.e. data that has no geometry)! --> <spatialrelationships> <!-- possible spatial relationships esriSpatialRelIntersects | esriSpatialRelContains | esriSpatialRelCrosses | esriSpatialRelEnvelopeIntersects | esriSpatialRelIndexIntersects | esriSpatialRelOverlaps | esriSpatialRelTouches | esriSpatialRelWithin currently unavailable: esriSpatialRelRelation --> <spatialrelationship> <name>esriSpatialRelContains</name> <label>entirely contained in</label> </spatialrelationship> <spatialrelationship> <name>esriSpatialRelIntersects</name> <label>interssected by</label> </spatialrelationship> <spatialrelationship> <name>esriSpatialRelEnvelopeIntersects</name> <label>intersected by envelop of</label> </spatialrelationship> </spatialrelationships> <bufferunits> <bufferunit> <name>UNIT_FOOT</name> <label>Feet</label> </bufferunit> <bufferunit> <name>UNIT_STATUTE_MILE</name> <label>Miles</label> </bufferunit> <bufferunit> <name>UNIT_METER</name> <label>Meters</label> </bufferunit> <bufferunit> <name>UNIT_KILOMETER</name> <label>Kilometers</label> </bufferunit> </bufferunits> <enabledatagridinteractionwithwidget>true</enabledatagridinteractionwithwidget> <toleranceforpointgraphicalselection>6</toleranceforpointgraphicalselection><!-- value is in screen pixels --> <tolerancebydefault>false</tolerancebydefault> <spatialreference>102003</spatialreference> <zoomscale>2400</zoomscale> <geometryservice>http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</geometryservice> <csvseparator>,</csvseparator> <disablebuttons>text,spatial,datagrid</disablebuttons><!--possible values one or more not all four search types comma separated text,graphic,spatial,grid,datagrid --> <defaultselectionoption>graphicalInput</defaultselectionoption><!--possible values only one graphicalInput or textInput or spatialInput --> <enabledrawgraphicbutton>true</enabledrawgraphicbutton> <enablebuffergraphicbutton>true</enablebuffergraphicbutton> <selectedgraphicaltool></selectedgraphicaltool><!-- possible values are extent or polygon or mappoint or polyline or nothing --> <multipartgraphicsearch>true</multipartgraphicsearch> <floatorfixed>float</floatorfixed><!-- possible values are fixed and float --> <relatetooltip>Show Relates</relatetooltip> <relateicon>widgets/eSearch/assets/images/i_relate.png</relateicon> <labels> <bufferusergraphics>Buffer Graphic</bufferusergraphics> <norelatesfound>No related features found for: </norelatesfound> <norelatesfoundalerttitle>No Results</norelatesfoundalerttitle> <addtolerance>Add search tolerance to point selection</addtolerance> <existingdrawgraphicslabel>Use Existing eDraw Widget Graphics</existingdrawgraphicslabel> <existingbuffergraphicslabel>Use Existing Point Buffer Widget Graphics</existingbuffergraphicslabel> <graphicalsearchlabel>Graphical Search</graphicalsearchlabel> <textsearchlabel>Text Search</textsearchlabel> <resultslabel>Results</resultslabel> <layerlabel>Search Layer:</layerlabel> <layerfieldlabel>Search Layer Field:</layerfieldlabel> <nolayerlabel>No search layer defined.</nolayerlabel> <submitlabel>Search</submitlabel> <pointlabel>Select by Point</pointlabel> <linelabel>Select by Line</linelabel> <rectanglelabel>Select by Rectangle</rectanglelabel> <polygonlabel>Select by Polygon</polygonlabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> <selectionlabel>Features Selected:</selectionlabel> <gridresultslabel>Show Results in Grid</gridresultslabel> <csvdefaultname>Selected Records</csvdefaultname> <relatescsvdefaultname>Related Records</relatescsvdefaultname> <exportbtnlabel>Export...</exportbtnlabel> <export2csvoptionlabel>Export to CSV...</export2csvoptionlabel> <export2txtoptionlabel>Export to Txt...</export2txtoptionlabel> <bufferlabel>apply a search distance:</bufferlabel> <spatialsearchlabel>Spatial search</spatialsearchlabel> <applybufferlabel>Apply buffer</applybufferlabel> <searchlayerlabel>Search entities of:</searchlayerlabel> <enablemultipartsearch>enable multi-part graphics</enablemultipartsearch> <zoomalllabel>Zoom</zoomalllabel> <zoomalltip>Zoom to all results</zoomalltip> <bufferalpha>Adjust buffer alpha</bufferalpha> <buffercolor>Select buffer color</buffercolor> </labels> <symbols> <simplefillsymbol color="0xff0000" alpha="0.5"> <outline color="0xff0000" alpha="0.8" width="2" /> </simplefillsymbol> <!-- You can have one or the other, either simplemarkersymbol or picturemarkersymbol defined for your point results NOT BOTH. picturemarkersymbol will override simplemarkersymbol if you do not have it commented out. --> <!-- <simplemarkersymbol style="square" size="12" color="0xff0000" alpha="0.5" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0x000000" alpha="1" width="1"/> </simplemarkersymbol> --> <picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0" /> <simplelinesymbol color="0xff0000" alpha="0.8" width="2" /> </symbols> </configuration>
