What is the operating system language?
OK finally got some time to return to this and wanted to update all on this issue. i tried the following things and it seem to fixed the issue. I did not have time to zero in on what fixed the issue. 1. Remove the ArcGIS folders(i had tried to remove them and install before so don't think this did it)2. Turn of User Access Control on the server during the install3. Remove all ArcGIS software from the machine and tried to install server on an empty machine. Once i tried to install after this everything seemed to install fine and the service is running fine. hope this helps someone facing the similar issue. Vijay
I had a similar issue, and had to uninstall Server and re-install. I guess something corrupted during the install.
I had the same issue as well... Uninstalling and re-installing worked only if I deleted the C:\arcgiserver\ and C:\Program Files\ArcGIS\Server\ folders before reinstall. (I did not need to uninstall my other ArcGIS Desktop and Engine installations).
I had the same issue when I changed the account that ArcGIS ran under (./arcgis is default). I resolved it by changing the file permissions on the arcgisserver folder and the Program Files\ArcGIS to allow access for the user that ArcGIS server service is running under.
I ran into same issue, with a different scenario.
reason: arcgisserver folder residing on network drive was inaccessible.
Hi, i had the same problem and this was solved by change in ArcGIS Server Properties to Log on as: Local System account
I'd contact support services and look for a better option. Running an application server as the local system account is highly unadvised from a security perspective.
I tried this still not work.
