Hi
before migrating to 100.x from 10.2.x there was an ElementLayer that we used to add images (regular bitmap images) to MapView after the migration the ElementLayer disappeared, is there a way to add a layer that displays regular bitmap images?
To display geo-referenced images, use either the RasterLayer which is optimized for this (it can even reproject to the right projection), or create a KML Document and add an GroundOverlay node to your KML dataset.
the bitmap image is not geo-referenced, it's a regular bitmap image.
so is there any way to display Image the is not geo referenced using some type of a layer?
