Hi there,
We have to create and maintain (with desktop scripting) a bunch of Collector Offline Basemaps.
Collector only supports tilePackages (.tpk) as offline basemaps.
To match our needs, we must use area of interest to generate the caches.
So we must use the ManageTileCache Tool to create caches on our AOIs.
We have all the tiledCaches, but we can't export them to .tpk files with the ExpotTileCache Tool wich seems to be made for...
The error is 000242 : layer not supported.
The tool can be run despite of the error and indicates for each scale level that the export failed.
BUT the .tpk is generated, with the minimum scale showing in ArcMap but all other levels are empty.
We tried to unzip the .tpk, copy and paste the missing levels, but only the minimum scale can be read.
Any clue will be welcomed to aim that goal.
Thank you in advance.
Best regards.
